rb25det cluster not working, Easy fix?
hey guys, i may be trading my car for a RB25 powered s13. One of the issues that is keeping me on the fence is that the gauge cluster does not work, except for turn signals. He has the skyline cluster, but i would much perfer to keep the s13 one for mph. Is this a difficult fix? anyone have any insight here? Thanks
![]() Join Date: Nov 2007
define "gauge cluster does not work"
cuz if it doesn't work at all then he wired something wrong....probably not too hard of a fix. But if the gauges are just innaccurate then that's to be expected. speedo signal from RB is KMH, vs MPH. So it should be off by close to a factor of 2. (mine reads almost exactly half of what it should). I think LS automotive makes a speedo that will work as for tach....6 cyl output vs 4 cyl tach causes it to read 1.5x higher. CarlH on nico will modify ur DOHC tach to work perfectly with the RB signal for like $50. That's what i'm gonna do when i have more money. hope that helps |
how much is their tach fix? I bet its more than $50......talk to carlh...trust me
and oh yea!!!! Get the VSS (speed sensor for the tranny) from a Z32 fits into the RB tranny and gives an output signal in mph. boom! but this is all assuming that the stock cluster is wired correctly. It does work right? just not accurately? |
#8 | |
this was brought up in a nother thread recently and S14DB informed me that the Z32 sensor with NOT fix your speedo reading
he said the 2 sensors are identical and the cluster must be modified |
![]() Join Date: Jan 2008
I have used the NA Z32 Speed Sensor in a Car and it worked no problem.
Also have used the Dakota Digital converter and that worked without a problem aswell. |
he said NA, and any Z32 should be the save (VG30DE)
that's interesting to hear it worded perfectly for you, since i've heard different things from different people. I guess the only way is to get one and find out! thanks for the info though. When using the Dakota Digital, did you notice any lag time in the tach? I've heard it has a slight delay in converting the signal |
#14 | |
Zerolift Autolab: Thanks! As far as the tach: I don't think I'll find anything cheaper than the $45 of shipping it to Carl H and having him calibrate it. |
![]() Join Date: Dec 2002
The VSS doesn't give signal in MPH or KM/H. The signal is the same for all units, if you look at a JDM gauge vs. a US you'll see the points match up, the only difference would be an auto unit vs. a manual. There is no such thing as a 'JDM' or 'KM/H' speed sensor.
#16 | |
so you're saying my USDM cluster is reading KPH on the MPH scale? I still don't understand it completely....because the way you're making it sound it should show MPH on my cluster, and KPH on a JDM cluster without having to calibrate anything So how do you explain people using Z32 VSS and having it work for MPH? |
so let me get this straight. basically my 2 options are:
1. get speedo recalibrated 2. Find speedo gauge face from (canada, uk, jp, anything with KPH as a primary scale, and MPH as the secondary) and switch with my MPH face right? |
#19 | |
#20 | |
As far the RB25/Z32 debate, I'm almost 100% positive it's the same too. It makes no sense that Nissan would build different sensors for different markets, and guys running JDM clusters in Z32s don't have to calibrate or swap anything to make them read correctly.
#21 | |
I don't understand why places like LS auto charge $110 for the "calibration" of the speedometer and the tachometer. |
