super multi junction plug question
first off does it matter how tight i tighten the multi junction plug?? cuz if i tighten it too tight, a blue relay with 5 wires coming out, (black, orangish, red-white, black-yellow, pink) that relay starts to buzz and my car lacks power, like as if no alternator is running, now if i dont tighten that much it works fine, but if i move it around a bit, the battery light turns on and everything dims like theres no power.... doesnt seem like a solid connection is being made... is it possible to rewire all the wires into the plug?
![]() Join Date: Jan 2003
How did the thing get lose in the first place? maybe try jumping the wire and just soldering it so you know its a good connection.
basically, to get the thing to lock you have to loom all the wires on one side, and open the little plastic thing, slide the connector in, and then relock it. |
almost forgot, this link should come in handy if you need to diagnose stuff
http://www.dragva.com/eng/M63.html |
