#1231 | |
#1232 |
Man w/ CTSV & a Car Seat
You can run some 10j +12 ish up front, even as low as +0 offset if you want to go low and run some camber. Stretch some 225/40-18s on them and it should be good to go.
#1234 |
Cant wait to get these rear dudes on (rebarreled)....tires just came in. 265/35/18 on an 11.5. Fronts are 18x10.
Fabulous profound ![]() ![]() gonna stuff them under some Origin Type 2's.
![]() Ls460, 240sx, Super Avenger, Chronofighter, Navitimer |
#1235 |
#1236 |
Hi,
I find an Enkei set for my s14. The question is will it fits without touching the rear shock? The front wheels size 18 width 10" and offset ET38. Rear wheels 18/9 offset ET35. Thanks! |
#1237 | ||
Rule of thumb...nothing wider than 8j and has an offset of +30 will clear the front suspension. Good rule to go with 9j +9 fronts, 10j +10...give or take 10mm for your own preference. |
#1239 | |
I think I've hit my quota of being in this thread for the night... ![]() |
#1246 |
Doesn;t that go with your recommended 17/18 x 9j +30 standard recomendation flip?
5mm spacers would not be needed with CO's with that if I read you correct
1996 Zenki 'Baraketsu Tenshi', Burst Angel My work in progress... |
#1247 | |
0 to -1 should clear with a 5m easy |
#1249 |
So I am about to order spacers for the front for my s14 and I am not sure what to order. I have searched and have not found any information on what size spacer I need. Right now the fronts do not clear the coilovers at all even with the 5mm spacer. The rears cleared with a roll and 5mm spacer. Wish I would have ordered a different width for the front but im stuck with them now. I dont mind rolling or pulling, just want it to clear suspension.
-Stock Fenders -XXR 526 18x10.5 +20 -Tein adjustable coilovers -20mm, 25mm, or 30mm? |
#1251 | |
#1252 |
turn the wheel to lock, then try and mount it up with the 5mm spacer. maybe try a 10 or 15 ,usually can only get those on slip on with extended wheel studs. a 20mm spacer will put you at 0, which might allow you to dial the camber back in.
edit: here is an 18x11 0 on stock metal from the wheel fitment thread being a half inch smaller should give you a little more play room for tire size or camber |
#1253 |
![]() Join Date: Jul 2009
Havent been on here for a while. Glad to see this thread is going strong! Continue to help each other out because that's what these forums are all about.
Frsh4
http://thatistupid.tumblr.com/ |
#1254 | |||
^^^Same shit I just typed up above Quote:
For a reference, here are my fronts, 18x10 +22 with 15mm spacers so they're +7. They barely clear my coilovers, once in a while, my springs would spin and the rims would touch them. I'd have to spin the springs so the rims wont rub on them. To give you the same clearance inside as me, you'd need closer to 20mm spacers but then your wheels will stick out further than mine by about 13mm. Quote:
#1255 |
Ok, so forgive me for the "noob" post. ive spent the past hour or 5 reading differnt wheel fit ups/ tire stretch/max rubber ect and didnt really find much info for what im wanting so ill post here..... i have a 98 SE, 300zx brakes all around, stance GR + coilovers (shit canned) and a few other misc parts. i really want to run staggred 19" Rohanna RC-5s.
fronts are 19x8.5 and come in off sets of 10MM and 35MM. 10MM would be the best fit up front correct? Rears are 19x9.5 and come in 20MM and 40MM offsets. so my question is what offset and tires would anyone suggest? Thanks in advance! |
#1256 |
![]() Join Date: Jan 2010
I haven't ordered the fronts yet, they're gonna be 17x9's.. I've been driving around with the rears though, I had to pull the metal out proly 5mm? and I'm running 4* of camber. I need to find a fender roller and clean up my pull/roll. The only thing is I got a borderline qp dent in the passenger side with the newspaper method and now I'm scared.. I wanna get the rears to about 2* of camber though, I'm gonna be taking the car to Texas from socal so it can't burn through tires like crazy.. Oh, and if my qp does dent all the way is it something the paintless dent repair people can get out? Just wondering..
#1257 |
that was for the front
#1258 |
Thanks for your help guys, I think im gona go with 25mm spacers for the time being and either buy new front wheels and use them as drift spares or go with a widebody in the future. Such a pain lol
#1259 | |
#1260 |
so 9.5 +20 on all corners would be your recomndation? what tire size ?
thanks for your help. |
