Old 12-16-2009, 11:51 PM   #1
sidedrifts13
sidedrifts13's Avatar
sidedrifts13 is on the path to ruinsidedrifts13 is on the path to ruin
Send a message via AIM to sidedrifts13 Send a message via Yahoo to sidedrifts13
SR sr20det ROD KNOCK QUESTION AND HELP??????
I have a red top sr20det and i just got it running today, the main reason why i am worried is when i rev the engine up to 3 or 4 rpm i hear a knock but not at high rpms and not at idle can it be a rod knock? Or just a lifter? I don't know, i am pretty bummed out, i think its a rod knock i will get a video up tomorrow, ima go out for a drive on my daily so i can keep my mind off it, dammm
I GUESS WHAT I AM TRYING TO ASK IS; IF IT WAS A ROD KNOCK WILL IT BE KNOCKING ALL THE TIME?
CLICK LINK BELOW FOR VIDEO IT DOESN'T SOUND GOOD
YouTube - S7303323.AVI
sidedrifts13 is offline   Reply With Quote
Old 12-17-2009, 12:03 AM   #2
sidedrifts13
Anybody have an input?
Old 12-17-2009, 12:32 AM   #3
Sileighty_85
Sileighty_85's Avatar
Yes it will quietly knock at idle and sound will get fast and louder as RPM's increase.
Is it a "Knock" or a "Tick"
Post a vid if possible
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-17-2009, 01:56 AM   #4
sidedrifts13
from the sound of it i would say its a knocking sound ill get a vid up tomorrow morning
Old 12-17-2009, 08:39 AM   #5
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
pull the oilpan and inspect for chunks of bearing...
TW: #/f/cars-sale/390459...d9s-coils.html
Ceepo is offline   Reply With Quote
Old 12-17-2009, 01:00 PM   #6
brian3676
brian3676 is an unknown quantity at this point
If it is knock then it will just get worse and worse, you have to do a rebuild before it gets worse and runes other things too if it is knock
brian3676 is offline   Reply With Quote
Old 12-17-2009, 02:39 PM   #7
sidedrifts13
video is up it doesnt sound too good damm no more money for this project
Old 12-17-2009, 03:39 PM   #8
sidedrifts13
anybody had the same knock?
Old 12-17-2009, 09:04 PM   #9
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
RIP SR20
That's rodknock. I've heard this 100 times
you've got two options
1backyard hope for you life 100 dollar gamble)...roll a new set of rod bearings in, one size over, hope for the best
2: Get a new long block.
Hope she treated you well, there's no mistaking that sound.
Old 12-18-2009, 05:25 AM   #10
sidedrifts13
I figured it was a rod knock this motor was definately a pain in the butt I was pretty bumep, but now i just got to move forward and figure out what i'm going to do, i just did a t28 turbo upgrade damm o well everything has a solution except for death really.... my 240 will be out of comission for a while but i cant wait to drift the f*** out of it
Originally Posted by codyace View Post
RIP SR20
Old 12-18-2009, 01:30 PM   #11
codyace
codyace's Avatar
Trader Rating: (58)
IF you do decided to reuse the block you have, just make sure your crank and rods are in spec. They usually are if you catch knock soon enough, and you can usually get away with new bearings and then you're happy forever.
Old 12-18-2009, 02:09 PM   #12
sidedrifts13
sounds like a plan im gonna get it fixed asap anybody know a good place where i can take it to? any local mechanics or mobile mechanics that would do the work?
Old 12-18-2009, 02:51 PM   #13
codyace
codyace's Avatar
Trader Rating: (58)
Are you in NJ?
Old 12-18-2009, 03:09 PM   #14
sidedrifts13
I am located in los angeles CA
Old 12-18-2009, 07:19 PM   #15
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Yup, thats definitely rod knock. Only other time that I head a knock like that and it turned out not to be rod knock was with Hypnotik. His shit wasnt rod knock, it was piston slap. His #3 cylinder somehow was shaped like an egg and the piston was slapping on the the side of the cylinder.
CLICK HERE!!!
Old 12-19-2009, 05:51 AM   #16
Walperstyle
Walperstyle's Avatar
if you are changing out the little things, you could also take this time to beef up the head, rocker arm stoppers, cams, and maybe different pistons and rods on the bottom if you wanted to go hardcore.
KA-T ORG-Function over Flush
Old 12-19-2009, 09:48 AM   #17
sidedrifts13
Some of my buddies dont think its a rod knock damm where in socal can i go get this checked asap?
Old 12-19-2009, 10:26 AM   #18
armand
armand's Avatar
armand is on a distinguished road
Send a message via AIM to armand Send a message via Yahoo to armand
yes my sr makes the same noise as yours at the exact rpm range no noise below or above that rpm range, my motor has been making that noise for 4 almost 5 years now ever since it was rebuilt. the noise has not got any worse overtime.i have pulled the oil pan many times and it been clean every time. my car is daily driven every day to and from work.i don't know what the noise is there have been other people with same noise at the same rpm range.
armand is offline   Reply With Quote
Old 12-20-2009, 02:58 AM   #19
steve shadows
steve shadows's Avatar
steve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfection
Send a message via AIM to steve shadows
If you can get down to LB tomorrow I will give you a couple hours of my time to check it out and give you a final answer. If it's what I think it is (other than rod knock) I may be able to fix it on the spot
Like Me on FaceBook !
steve shadows is offline   Reply With Quote
Old 12-21-2009, 06:18 PM   #20
sidedrifts13
anybody else have any input before i part it out??????????????????????????????
Old 12-21-2009, 11:44 PM   #21
steve shadows
checked out the car today in person.
This should go as a lesson to swap shops and other DIY'er to make sure to pull the oil pan and check the oil pick up condition as well as hammer out the oil pan or use an upgraded one right off the bat.
These motor's are seriously sensitive to oil starvation of any kind.
I have suggested that he pull the oil pan, check for copper filings from any possible bearing wear and replace the oil pick up if it's broken.
If the oil pressure is just started to fail then you can catch it, get the oil pressure back up to where it needs to be and eliminate the little amount of metal on metal knock you are having with your motor. Saving it.
But it will be a close one.
Old 01-13-2010, 03:23 AM   #22
sidedrifts13
Okay guys so I finally droped my oil pan and i found some brass shavings in the oil and also a thicker piece of brass which i am trying to figure out where it came from because it is thicker than a rod bearing and its brass on the inside and outside any ideas???????? i will have pics in a bit
Old 01-13-2010, 03:41 AM   #23
sidedrifts13
The small piece looks to be like a brass material anyone know where it could have shaved off from? thanks for the help and sorry for the crappy cell pics
Old 01-13-2010, 07:17 AM   #24
codyace
codyace's Avatar
Trader Rating: (58)
brass could be from a thrust bearing? hard to really tell
Old 01-13-2010, 11:11 AM   #25
sidedrifts13
that's what I was thinking anyone else have an input? thanks
Old 01-13-2010, 09:50 PM   #26
Ceepo
Ceepo's Avatar
at least your bearing didnt look like this lol...
This is what my oilpan looked like when i bought my motor...
I hope all goes well with repairing your motor... i honestly would rebuild that motor...
Old 01-14-2010, 12:38 AM   #27
sidedrifts13
yeah mine wasn't that bad but still need to find out what that bigger brass piece is from i wonder if its from the trust bearing, or even the timing chain tensioner
Old 01-14-2010, 09:58 AM   #28
codyace
codyace's Avatar
Trader Rating: (58)
Tensioner would either be plastic or metal
Old 01-14-2010, 05:38 PM   #29
sidedrifts13
tensioner would either be plastic or metal
cool thanks i ima go get a rebuild anyone know where do they do good work for good prices here in socal? Thanks
Old 01-14-2010, 06:13 PM   #30
Shorsh
Shorsh's Avatar
Shorsh is just really niceShorsh is just really niceShorsh is just really niceShorsh is just really niceShorsh is just really niceShorsh is just really niceShorsh is just really niceShorsh is just really niceShorsh is just really nice
Send a message via AIM to Shorsh
put a b16a in your 240
GSPEED CORP - GARAGE BOSO - MOSHI POWER
Shorsh is offline   Reply With Quote
