Old 07-10-2013, 10:51 PM   #1
burgessn
burgessn is an unknown quantity at this point
S13 PBM subrame risers
Hey guys I was just wondering is anyone running Driftworks hubs and PBM subframe risers?
I am having some trouble. I also have PBM coilovers and the rears set as tall as they can safely go are just way to low.. with the car on stands still the tire is already tucked into the fender well almost to the rim!! its ridiculous
Bn sport blister kit with 18x10's and 225/40 tires just if anybody wanted to know..
Any thoughts??
burgessn is offline   Reply With Quote
Old 07-11-2013, 08:44 AM   #2
burgessn
Bump bump!! anybody had similar issues!!
Old 07-11-2013, 08:57 AM   #3
tobroketobuildarealcar
tobroketobuildarealcar is an unknown quantity at this point
Post pics something dosent sound right
tobroketobuildarealcar is offline   Reply With Quote
Old 07-11-2013, 11:21 AM   #4
G5SR20240
G5SR20240 is an unknown quantity at this point
you have the lower section of the coilover threaded down as far as it safely can go?
G5SR20240 is offline   Reply With Quote
Old 07-11-2013, 12:22 PM   #5
burgessn
correct the coilovers are extended to there maximum length (about 3 threds left) and they are super low still. i know this is weird as most people want there 240 slammed but i actually want a lil ground clearance lol
Old 07-11-2013, 03:57 PM   #6
G5SR20240
you might just have a bad combo, those coilovers are giving you the ability to be slammed on stock uprights, could be too much
Old 07-11-2013, 03:58 PM   #7
PoorMans180SX
PoorMans180SX's Avatar
How much camber are you running in the rear?
Old 07-11-2013, 06:03 PM   #8
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Post up some freakin pics
Old 07-12-2013, 12:58 AM   #9
DennisC
DennisC's Avatar
DennisC is an unknown quantity at this point
You need to use s14 shock. Go on the pbm site and order 2 replacement shocks for the S14 rear. They are a extra few inches longer so you can safely raise your car back up.
DennisC is offline   Reply With Quote
Old 07-12-2013, 09:16 AM   #10
burgessn
i am running zero camber in the rear.
i will post a pic this weekend
and i will look into the s14 shock option. i thought about this before but i was un sure if it would be to much longer..
thanks everybody for the good info
Old 07-12-2013, 09:33 AM   #11
burgessn
damn 200 bucks for these. thats not bad for new shocks but it is if you get them and they dont work lol....
Old 07-12-2013, 09:36 AM   #12
From my understanding of the rear drop knuckles the suspension pickups are raised while the wheel bearing mounting points remain the same causing a false drop and restoreing factory loke suspension geometry. This would not cause the car to sit any lower but it will effect the angles of your suspension arms
Old 07-12-2013, 10:38 AM   #13
PoorMans180SX
You have it backwards. The hub mounts/ spindles are pushed up in the knuckle. This drops your car however far the hub was raised, from it's current height. So Driftworks Drop the car 45mm front and rear.
They will work.
Old 07-15-2013, 09:17 PM   #14
burgessn
Set at there max ride height lol....
