hey guys i need some help here. so i was checking out the megan s13 rear adjustable toe arms and they said the fit on an s14 so does anbody kno if they really fit on the s14? thx a lot.
The S13/S14 toe arms are the same length but the inner bushing on the S14 is a little wider so you'll need something to take up the extra space if you put the S13 versions on the S14. If they advertise one size fits both they may include spacers. If not, a couple of washers will do the trick.
