Old 08-19-2010, 09:14 AM   #1
marshallpre1
marshallpre1 is an unknown quantity at this point
RB25 S13: Ridiculously hard clutch pedal
I noticed this earlier this year when I bought the car, but thought it was just normal, until earlier this week I pressed it and broke of the tack welds and bent the assembly. I was towed to the shop and they fixed it (welded it back on). However, is there a reason my clutch is ridiculously stiff? The clutch is an ACT 6 puck with unknown lb pressure plate (running an RB25 tranny). My Supra has a heavy clutch too, but it's only a little bit heavier than stock. My 240 feels like it's triple the stiffness.
Any advice? Any upgraded slave/master cylinders out there?
Thanks,
Jeremy
97 Supra TT/94 SC300 NA-T/04 G35C/10 G37 Sedan
marshallpre1 is offline   Reply With Quote
Old 08-19-2010, 11:04 AM   #2
Sileighty_85
Sileighty_85's Avatar
you can try upgrading to a full SS clutch line if you still have that short rubber section (or just replace that short section) up to you
Nismo does make an Upgraded Slave cylinder that might help
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-19-2010, 12:01 PM   #3
marshallpre1
Do you know of any vendor solutions? Maybe I'll just try replacing the slave for now..
Jeremy
Old 08-19-2010, 04:38 PM   #4
Sileighty_85
The Nismo Shop : West Covina Nissan : NISMO RB20/RB25DET Slave Cylinder
後輪駆動車1番
1986 SR86 - 200ish
