#94 |
Got my oem 5 lug hubs in!
Rear suspension all done finally! The. Hit another snag. I have 26mm 300zx brakes and got 30mm rotors on accident. Sweet more waiting
#96 |
Wiring specialties AEM harness came in! Already routed it in the bay.
And got a couple cheap rear tires to destroy Running fuel lines tomorrow, welding on the iat and bov flange. Just waiting on new front rotors and the front wheels to come in. Hoping to be a roller this weekend so I can start the interior. Unfortunately I'm just about broke so a cage has to wait :\ I'd rather buy a motor for the FD than a cage anyways
#98 |
Some more cool shit
Mounted up and put them on the car. I'm amazed that the wheel slightly touches the coilover. They are 18x10 +18. Going to run a 15mm bolt on spacer to fix that (:
#103 |
Well done! Can you give more details on your power steering setup? Specifically that blue high pressure line, thanks.
* S14SR22 * 9.0 c/r * GT3071R * |
#105 |
It's one I had custom made by a guy that does industrial plumbing. Most of the kits you buy barely thread into the pump, which is idiotic. He matched all the oem fittings and I just gave him the length I needed. My shop has them in stock for KA and this was our first sr setup
#107 |
This exact one!
16-Gauge Steel, Single-Axle Trailer Fender, 10-3/4" Wide - 14" to 15" Tires Redline Trailer Fenders F1075X32-1R
#108 |
Let me know if you get any more made for an SR, I might grab one since it's only a matter of time before my high pressure lines turns into a low pressure line...
#110 |
yeah just cut it in half, rounded the tops by the strut tower and they fit great. life was made easy with the plasma cutter however. if i ever had to do it again, i would NEVER do it without that tool.
#111 |
was that Kyles S13 before ? it sure looks nice, a lot of attention was paid to the detials.
Much like your S14. looks great dude!
Two-Tone owner#011509-Lightly Modded
#112 |
she got some sunlight today for the first time in 5 months
and yes i know i need to put the spacers on... keep in mind these wheels are intended for the FD. ill probably buy some nice wide wheels next summer when im not broke again
#113 |
yes it was kyles, the outside of the car is fantastic. wiring wise is another story.... all new harnesses are being ordered for it, they are beyond repair. and the exhaust fell off by the turbo. the car still needs mad love, and it will get it for sure when Jake and I are around. thanks dude!
#119 |
Well getting In the rush to just getting the car done. But I made a bracket and installed the hydro
And powder coated in sparkle purple of course Started on the wiring and puting the fusebox on the dash Moved the car to my other buddies shop to make the exhaust Fits amazing and is right against the frame rail Tig welding the down pipe Told maya, the shop pit, that there was a squirrel in the box so she instantly destroyed it Sweet view from upstairs. His shop is like Tokyo drift And done! I ordered a turbo blanket and wrap for the down pipe too
