![]() Join Date: Apr 2009
Oh man. I remember my first plenum pull. Easily the most annoying thing I had ever done to a car. All the old brittle hoses and the gasket that took a life time to scrap off.
Did you test resistance on the injectors to see if they are good. Should measure between 10-14ohm.
If not good they will need to be replaced. This is the best type to upgrade to j30 or type 2 injectors that do not fall apart due ethanol. I tested mine on my z and they tested out to 11ohm thank goodness I didn't want to pull the plenum to replace. |
| 1990, 2+2, 300zx, build, project car |
