![]() Join Date: Nov 2016
Need help to diagnose no fuel no spark
Alright guys so yesterday took the car to the track, car ran perfectly fine. Didn’t want to push it too hard so I wouldn’t have any problems on my way home (no trailer).
As I let the car take a break and cool down I started packing up. I go to start the car and cranks but no start. No pressure from the pump, so I go to diagnose and the fuel pump relay wasn’t getting ground, as soon as I jump the relay to ground I had fuel pressure. So I crank again and no start. Found out I had no spark as well !! I was carrying my obd2 scanner and when I plug it in, it doesn’t connect to the vehicle. Diagnosed for about 2 hours at the track before giving up and towing home. I searched here and other forums, with no real definitive answer. It is a 97 with a ka24de. I’m suspecting ecu problem, eccs relay, possibly distributor (built in cam angle sensor) or maybe some wiring problem between fuel pump relay and ecu. Checked all fuses and all are good ! But anything I may be missing would be a great help guys , cuz as soon as I’m off of work ima rush home and start poking around . Thank you in advance Sent from my iPhone using Tapatalk |
Update guys! For anyone having the same issue, I solved it in about 10 minutes at home...
I cleaned my ground wired on the head on the exhaust side, and I pulled the ecu, checked the eccs relay behind it, and the relay was not responsive, so switched it out with a working one and car fired right up Sent from my iPhone using Tapatalk |
