![]() Join Date: May 2010
rotors for s13 with z32 calipers
Ok so I pulled some calipers off a z32 in the junk yard. But didn't grab the drum assembly off the back. I plan on just running a hydro setup as an ebrake. But my question is, what rotors can I run for the rears? Again I don't have any of the stock ebrake setup. Thanks guys
![]() Join Date: May 2004
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
you can run z rotors... just drill them to 4 lug if you aren't 5 lug yet. you don't need the ebrake assembly to run the rotors if that's what you're wondering (from the way you worded your post).
bew bews! |
