![]() Join Date: Jun 2010
Trader Rating: (55)
![]() Feedback Score: 55 reviews
Massive Garage cleanout!! Many parts you may need to sexify that sexy thang of yours!
Contact: (562)309-1815 (moses) Call or text
Location: Whittier, CA Shipping: YES Paypal: [email protected] note: if sending payment for any of these items, please leave a note as to what you want. Also give me a text to let me know also. CAN ALSO COMBINE SHIPPING!!!!! All my stuff is tested and in working condition when it is shipped out. single din cupholder-SOLD coolant reservoir-$30 -comes with the rubber hose and the mini clamp that hooks to the radiator -has a little stress mark as shown -holds water fine pignose/silvia front turn signals- SOLD I have a rear speaker deck for s13 coupe that I have been saving as a spare just in case I decide to cut my current one. I have decided not to cut and am selling this one The hole you see on the left hand side is not a rip. They come like that. The right side can be pressed out as well. Selling for 50$ good condition. the pics will do the talking No Shipping (FRONT)s13 calipers, drilled and slotted rotors, dust shield, hawk hps brake pads(less than 6k miles on the brakes and rotors) -$90 s13 KA24DE Exhaust cam- SOLD s13 open diff with j30 cover (worked well needs gasket and fluid) Will fit s14 or swap the cover and it will fit s13. - 40$ s13 Fuel Pump Ka24e/Ka24de (USED)-40$ S13 Coupe Trunk/ gas door cable-$45 Manual Transmission Brake Pedal-SOLD Random 330mm? steering wheel (no horn) $20 passenger gray sunvisor-$10 s13 KA24DE fuel rail-$30 piece needed to mount Chuki fender extensions-$5 tweed glove box-$15 passenger side headlight motor-SOLD Metal car ramps-$100 fan shroud-$15 modded auto trim for manual-$5 auto trim-$5 Silver headlight trim-$5 s14 Seat belt clip-SOLD!!!! S13 passenger headlight cover-$5 painted black passenger sunvisor-$5 Auto Shifter- $5 SOHC TIMING COVER-$20 coupe tail lights- $30 has little crack on the left side. stock s13 springs(fronts and rears)-$40 TIRES (2) FALKEN ZIEX 235/45/17 90% thread (no patches or cracks)-$80 -bought this a while ago because my cousin was going to get rims -he changed his mind on the rims so they are just sitting in my garage -I need space and have no room for them. (1) Nexen 30% thread 205/40/17 -$15 (2) FEDERAL 595 205/40/17 has pretty thick thread still, has camber wear, each has a nail in thread but did not puncture tire one has sidewall cracks. $30 for both (1) FEDERAL 595 215/40/17 Has a nail in the thread that did not puncture through. has some camber wear, thread is pretty thick still. $20 They will definitely brighten your interior by ALOT!!!! The color of the light is white selling 20$ each 23$ shipped to your door if interested hit me up at 562-309-1815(moses) if you want it shipped, send payment to [email protected] make sure to leave a note that you want this or pm me afterwards key ring lights (will come with installation instructions) 20$ picked up 25$ shipped s13- this item is a perfect fit. s14- you need to trim the plastic a little to fit. 5 colors available Blue Green, Yellow, Red,or White LED each light comes with a pigtail so that you can wire it in, and unplug it whenever you want. pics What it looks like mounted blue red green white yellow Wedge smd (SUPER WHITE) HAS 20 SMD on each bulb (brighter than last set I had for sale!!!) WORKS FOR s13 and S14 (many other cars as well!!!) $6 each or 3 for 15 picked up (whittier Ca 90604) 3 for 18 Shipped (VIA USPS FIRST CLASS) 6 for 34 Shipped (VIA USPS FIRST CLASS) The DIMMER function will still work with these leds can be used for: cluster (requires 3) hud cluster (requires 6) sidemarkers(requires 1 for each), third brake light (requires 2) the running light for half amber half clear turn signals( 1 for each signal) trunk light( requires 1) example Last edited by aznfab213; 11-08-2012 at 07:10 PM.. |
![]() Join Date: May 2010
How do u guys mount those side markers? Just got a set from junk yard but trying to figure out how mount them securely. Freeee bump for you.
http://upsidedownsideway.tumblr.com/ |
