Old 07-07-2012, 09:54 PM   #1
nunnyjr
nunnyjr is an unknown quantity at this point
Boxer Sound from my sr20 and loosing boost
Hi im trying to figure out why my sr20 is sounding like a suburu sti when i give it more then half throttle. Im really confused and my boost gauge says im not loosing boost but i know i am because it doesnt pull like it should. Could it maybe be a bad coilpack? Could my boost be turned up to high?
Could my turbo be going bad? please help!!!!!
nunnyjr is offline   Reply With Quote
Old 07-07-2012, 10:14 PM   #2
Giebs
Giebs is an unknown quantity at this point
seen similar issues when the timimg chain jumped a couple teeth.
327k, 8 track events, and still goin.
Giebs is offline   Reply With Quote
Old 07-07-2012, 10:21 PM   #3
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
That sound you hear is gonna be a misfire
Old 07-07-2012, 10:25 PM   #4
silviaks2nr
silviaks2nr's Avatar
check your plugs and your coilpacks and pressure test your charge piping.
Old 07-08-2012, 11:34 AM   #5
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
Check ur timing too. If its boosting but no power under load. Could be related.
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 07-08-2012, 11:40 AM   #6
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
Send a message via ICQ to EDacIouSX Send a message via AIM to EDacIouSX Send a message via MSN to EDacIouSX Send a message via Yahoo to EDacIouSX
last time I heard a "boxer" sound from an inline engine was when a friend blew a ring...
EDacIouSX is offline   Reply With Quote
Old 07-08-2012, 12:31 PM   #7
Sileighty_85
Sileighty_85's Avatar
fuel injector, Coil pack, Spark plug
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-09-2012, 05:11 AM   #8
nunnyjr
Its like almost any throttle at all it has virtually no power
Old 07-09-2012, 06:47 AM   #9
revert
revert is an unknown quantity at this point
My buddy had similar problems but the valves hit the cylinders
revert is offline   Reply With Quote
Old 07-13-2012, 05:58 AM   #10
nunnyjr
boxer sound
I firgure out it was just a loose fuel injector wire. No big deal which is always a good thing.
Old 07-15-2012, 02:57 PM   #11
Sludge805
Sludge805 is an unknown quantity at this point
Your lucky then ha my boxer sound ended up being a bent valve broken rocker arm and I beat up cam
I am here: http://tapatalk.com/map.php?ymsyhm
Sludge805 is offline   Reply With Quote
Old 07-15-2012, 08:55 PM   #12
nunnyjr
Damn man that sucks. Wasn't a cheap and easy fix was it?
Old 07-16-2012, 11:01 AM   #13
Sludge805
Haha I'm still saving up! But congrats on figuring out it was just the injector before you took everything apart
I am here: http://tapatalk.com/map.php?kp01m4
