![]() Join Date: Oct 2008
Trader Rating: (38)
S14 kouki ka into 95 zenki
Sup guys ,im almost done with this swap ,but some plugs from the zenki chassis are different , specially the one from the starter, the zenki its a 2 wire plug and the kouki its a 3 wire plug ,also the windshield wiper plug its different too . is there a way to
Modify this , i searched already . This is everything i got from the kouki Motor Tranny Harness Ecu Lower harness Thanks . |
![]() Join Date: Apr 2008
The wipers are easy,u just have to find a clip to match your zenki wiper motor, .....one wire is power,one wire is ground,the rest are speed,low, med,high, turn ignition power on,turn wiper motor ON,then put a test light to the wires to see which is power and so on,then just rewire to new zenki clip accordingly.
Trader Rating: (38)
My friend told me to find out about the two skiny wires from the kouki harness,cause the fat one will match the strter signal but i wanna know what r the other 2 wires for .
I downloaded the fsm and cant find shit . |
![]() Join Date: May 2009
LOL I had the same problem. I am about 90% sure those are for the transmission. I can't remember. I had mine jimmy rigged with a jumper for the starter and left the two little ones alone. Car runs fine.
Sorry about wait, fat wire is starter,one is oil sensor,one is tranny,on the kouki the 2 top ones are starter and oil,the bottom by itself is the tranny one,so you can either cut off the kouki clip(very important to cut one wire at a time,rewire,then cut the next wire,this will allow you to not mix the wires up or forget which wire is which) and replace it with a zenki clip and re wire accordingly now that you know what the wires do, it should take about 5 mins or less,if you dont have a zenki style clip, just tap into the kouki lines and add wires and connect them directly to the chassis wires,also easy because you now know what each wire does,opening the lower harness completly will help you understand what each wire does,but not neeeded.
#17 |
Trader Rating: (38)
can u guys tell me where does the brake booster goes connect it on the s14 ka ? Sorry guys this is my first ka swap , i,ve done pure rbs since i started in the 240 scene
#21 |
thank you ur a life savior
yay my sr is wired! i followed this guy #/f/tech-talk/209158...4-chassis.html |
