Alright guys i have a 1996 240sx with a redtop sr20det. I need to change the coolant temp sensor because it is reading wrong. which one do I get? i tried the one for the 1996 kade but the plug won't work! the 1995 one will plug in, but will it work??
Thanks for any help!! |
![]() Join Date: Dec 2002
S13 KA. Match the sender to the engine for the ECU, sender to the chassis for the gauge.
Bandwagon.
Man w/ CTSV & a Car Seat
S14 sensor should work. You match the sensor with the gauge cluster you are using. You sure you swapping out the right sensor?!?! There are 2 sensors on top of the water pump housing, swap out the 1 wire sensor with your S14 KA one.
I bought a coolant temp sensor for a 92 KA, tried to put it in my blacktop sr but the threading on the sensor isnt the same as the threading I have inside the bank. Its the two pin ecu sensor. Help fast so I can get this done tonight. Also, the connector works but I cant get it to thread into the motor....http://www.autozone.com/autozone/cat...&parentId=59-0
| coolant temp sensor, redtop, s14 sr20 |
