![]() Join Date: Apr 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
GTi-R Internals in S13 SR20DET?
Stupid question alert:
How similar is a GTi-R SR20DET to an S13 SR20DET? I know you can't use a GTi-R head or block in a RWD application, but can you use the internal parts? Long story short, I spun a rod bearing in my blacktop S13 SR20DET. It needs a new crank and a new rod. I'll be doing new oil pump and new bearings while I'm in there. I have been trying to source another long block to use for parts, but I got an idea I thought I'd run by someone who knows more about SR's than me ![]() I was thinking about getting a GTi-R motor, using the crank, rods, pistons, etc. to rebuild my current block, and you get the added bonus of an ITB manifold w/ top feed injectors (which needs to be cut/rewelded to be used on an S13, I know) and a decent T28. Also, doesn't the GTi-R use solid lifters? Can the head internals be swapped into an S13 SR20 head? Suggestions? Errors in my logic? Thanks in advance.
The crank in the GTi-R motor has wider journal areas and uses wider journal bearings, but I don't remember if it will swap directly into a RWD block or not.
As for the solid lifter stuff, yes, that all will swap to a RWD head. As a matter of fact, I think 1 of the company's conversion kits out there is basically just RNN14 stuff. However, if you have a black top S13 motor, chances are you already have 54C pistons and stuff, which are the same stuff as the RNN14 pistons and what not. So really, you're looking at possibly being able to use the crank/rods from the RNN14 motor, the intake stuff after you've cut and rewelded it, the injectors, and the solid lifter stuffs. Good luck w/ the rebuild Sean! |
Neat. Thanks for the info buddy
![]() Anyone have a definate yes/no on the crank? Thats the main piece I need. I would also like to swap out pistons, since whoever owned this motor before me was a moron, and put the rocker arm guides/shims in backwards causing the valves to open slightly too far and whack the pistons. Not hard enough to damage them, but it put little dimples in all of them. So if I can use the pistons out of a GTi-R motor that helps too. Haha. I've also been reading that the GTi-R oil pump flows better than an S13 pump, and fits with some modifications... hmm.
http://www.cardomain.com/ride/208651/8 Can I keep my Nismo flywheel/clutch set up from my S13? Or will the 2mm bigger flywheel bolts prevent that? I suppose I could get the flywheel bolt holes machined 2mm larger... thoughts on that?
Nevermind, I answered my own question. While the bearings themselves are wider, the actual rod caps are the same size...
rods look a good bit thicker too. which would be nice.
Well then, get to work meng
![]() Join Date: Jan 2007
i believe you can run the gtir conrod bearings
i just ended up getting a GTiR fly wheel and bolts from a friend. instead of drilling the flywheel, then getting it balanced and stuff to suit... here in aus we have shitloads of GTiR parts so that was the easiest thing to do good luck !! any questions just ask
This pic is between SR20DE vs SR20DET rods.. LMK if you need verification got bunch of those.
You should be able to run solid lifters setup from the GTi-R on the S13 SR
