elongate exhaust manifold holes for a sr20ve
i'm planning on using a stainless steel bottom mount turbo manifold on a sr20ve head
the manifold fits perfectly but the ports are off by 1/8" now my question is ,can i just elongate the holes on the manifold flange cause it lines up perfectly with the holes elongated or would this be a problem |
Yes, you can elongate the holes. I did the same for my Peakboost DET manifold for my VE conversion.
My SR20VET |
#6 | |
![]() Join Date: Mar 2011
i.e. Did the ports match properly?
www.motoredge.wordpress.com Last edited by Conrad 2NR; 03-28-2012 at 09:44 AM.. |
The VE's exhaust ports are the same dimensions as the DE/DET...
My SR20VET |
Thank you.
www.motoredge.wordpress.com |
