![]() Join Date: Aug 2011
Sup forum im bulding my first sr20det after owning rb's and and ca's. why the sr and not rb's anymore cuz i just had the engine and next 6 inline id go for is the 2jay. anyways back on topic this is my build to date and i want to ask if any one have similar builds whats the power output could be (id like to aim for 500whp)
S15 Sr20Det CP pistons 86.5 9.0:1 / eagle rods /acl bearings/arp studs full race front face manifold/ Intake side is still stock with a 70mm TB 1000cc injectors paired with fuel cell and a BG king sumo pump Shoping for turbos, looking into these: gtx3071/td06 20g (dont know if the 25g is that laggy) Cams are still stock but im looking into some 264's all BC that's basically my setup may have left out some details but i think i pretty much covered the main. I will be running on a fueltech ecu. I will want to drive the car on open roads still so i wont be going over 20psi/21psi of boost (fuel of my country wont allow it). what do you guys think i will be pulling out of this considering the choice of turbos and cams. and also will my stock intake manifold restrain me for power gains/is it that important to get an aftermarket one with 90mm slammed to it. can check the ride in progress here (totally new build from scratch progress 80%): thanks forum |
