Will the S15 3.69 ring/pinion work in an S14 ABS diff?
Its taking a long LONG time for my s15 diff housing to arrive from thailand, which happens, but i need to cover my bases as im about to pull the KA for my vvti 1uz swap and need a source for a speed signal, which can be provided via the s14 ABS diff or the s15 diff, i already have an S15 HLSD currently in my non-abs s14 diff and also have the 3.69 r/p sitting on the floor of the shop. I need to use this ring and pinion to avoid excessive highway rpms. So if its possibly to run this ring and pinion in an S14 ABS diff then thats all i need to know. Externally they seem the same. They both incorporate a speed sensor on the rear diff.
