Old 10-26-2020, 05:40 AM   #601
PoorMans180SX
PoorMans180SX's Avatar
Checking out the main bearing clearance, it's pretty much perfect at .0015-.0018", and the rods are at .0024" which is mint as well. Measured with a proper bore gauge.
Oil squirter "delete" will be replaced with some proper Mazworx ones.
Super Beefy crank doesn't allow squirters it seems.
Timing chain squirter will be replaced with a Taarks screw in.
Old 10-26-2020, 05:45 AM   #602
PoorMans180SX
Here's some of the detail work that I do to my bottom ends. Basically smoothing out casting flash, breaking sharp edges, Smoothing out oil drains and feeds, etc.
Why does no one ever address the terrible water inlet on SR20 blocks? It's a ninety degree cross drilled passage that has to see a bunch of turbulence.
Just cleaned up some more flash in the water pump area.
Old 10-26-2020, 05:54 AM   #603
PoorMans180SX
Also, SR20 blocks have these weird plugged, unused passages that run to the sump. I may try and simplify my catch can setup by using the top fitting as a drain. I gotta knock that aluminum plug out so I can use the factory crankcase vent, but I think I can re-route the PCV system so in vacuum/cruise it takes the proper path of through the air intake, down into the sump, up through the timing cover and out the valve cover. Kinda nice for detail people like me hah.
Off to the machine shop today!
Old 10-26-2020, 08:24 AM   #604
PoorMans180SX
Just learned from a very reputable SR20 builder that my main clearances are much too tight. Guess I'll order up those .001" extra clearance bearings hah.
Old 10-26-2020, 08:31 AM   #605
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Its funny. When you posted the mains and rods, I had to go look them as they did seem too tight. Especially if you want to put some big turbo heat into them.
Good catch!
Old 10-26-2020, 09:08 AM   #606
S14rebuild
Kinda weird on the crank to big for squirters
Old 10-26-2020, 10:03 AM   #607
PoorMans180SX
Good catch!
Thanks, I guess I'm used to iron block 4G63's that must move around less? The rods should be fine as far as I'm aware, but I guess #3 main should never be less than .0030"! Which is much larger than I'm used to seeing. Mine is at .0012" so I'm going to have to do some finessing.
I'll be test fitting everything to see if I can run them or not.
Old 10-26-2020, 10:40 AM   #608
PoorMans180SX
A friend of mine let me thrash his NA KA car a few weekends ago. It was fun sending this thing in third.
Old 10-29-2020, 05:29 AM   #609
PoorMans180SX
Got the THL crossmember in.
Got the GKtech one-piece arms in, the car back on the ground, and got it to a more proper ride height.
Still need to install these and a hundred other things.
Old 11-01-2020, 11:28 AM   #610
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
Everything looks good. I wouldn’t omit the piston squirters if I were you. On the oil drain holes, did you just chamfer the hole instead of having a 90* edge? I’ve contemplated doing some of these things on my “big power” build.
My SR20VET
Old 11-04-2020, 06:46 AM   #611
PoorMans180SX
Everything looks good. I wouldn?t omit the piston squirters if I were you. On the oil drain holes, did you just chamfer the hole instead of having a 90* edge? I?ve contemplated doing some of these things on my ?big power? build.
Yeah I'm going to try and fit the squirters back in. Yes, I chamfered or radiused every oil drain and feed area it made sense to.
A bigger update later this week.
Old 12-29-2020, 07:15 AM   #612
PoorMans180SX
I've been taking a little break from this for the Holidays, but here's an update:
http://www.youtube.com/watch?v=i9q-V9CZzQg
Old 01-08-2021, 05:34 AM   #613
PoorMans180SX
Well, one more piece of the puzzle.
Old 01-21-2021, 10:22 AM   #614
PoorMans180SX
Anyone interested in an old-school style writeup on the SR20 wiring harness build? Obviously I'm doing a video about the whole thing, but I can take pictures and do a writeup if people think that would be beneficial for the forum. I'm going to be building the harness to be future proof so it would include some extra sensor provisions and all the things to run the VVL system for a VE head conversion.
Updates on the car coming soon.
Old 01-21-2021, 12:35 PM   #615
e30gangsta
That would be super awesome/beneficial even if its a youtube video.
Need aftermarket parts? PM or DM me competitive pricing! [email protected]
Old 01-21-2021, 12:39 PM   #616
IIIXziuR
IIIXziuR's Avatar
Is that you with the very manly beard and high quality branded flannel shirt? Very nice!
I would be interested in seeing your process on the wiring harness build!
I may have missed it but you aren't doing anything with those VG33's anymore, huh?
Old 01-21-2021, 02:49 PM   #617
PoorMans180SX
Thank you for the feedback!
Haha, indeed that is me. Nah, the VG33 was supposed to be a budget build for me and it got out of control much too quickly. As you can tell, I tend to "spaceship" things, or make them way more complicated than they have to be. Not to mention when I stopped working at the shop I lost the ability to weld things, which was pretty key for that whole setup. I sold them all to my local Z31 friend.
I'm still kind of undecided on what engine is going in the orange car (That I really, really don't want to be orange anymore).
Old 01-30-2021, 05:03 PM   #618
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
why no ecu master?
supersayianjim is offline   Reply With Quote
Old 02-08-2021, 02:56 PM   #619
PoorMans180SX
Originally Posted by supersayianjim View Post
why no ecu master?
Because I dislike ECU master connectors, this will allow me transition to a different ECU if I want, and I got a sweet deal on this. Might run an ADU5 though!
Finishing up the nitty gritty of planning out this harness. A few more big decisions to make and then it's mockup time for the ECU to firewall.
Old 02-08-2021, 11:17 PM   #620
RalliartRsX
Trader Rating: (32)
As an ecumaster user, I share that sentiment.....
Old 02-15-2021, 07:49 AM   #621
PoorMans180SX
Yeah right?
I've made a few mistakes on this car in the rush to get it ready for last season. I'll show ya'll some of them this week, including what not to do on a rear subframe and why you don't want to try running one-peice S14 FLCA on an S13...
Old 02-15-2021, 08:34 PM   #622
PoorMans180SX
This is the kinda shit I?m talking about.
Old 02-16-2021, 03:02 PM   #623
PoorMans180SX
Time for subframe redo, round 2.
Old 02-16-2021, 05:31 PM   #624
RedSled
RedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-known
what caused the subframe to split like that ,that's very disturbing
RedSled is online now   Reply With Quote
Old 02-16-2021, 05:47 PM   #625
RalliartRsX
Trader Rating: (32)
Looks like some jackass shoved the aluminum bushings into the housing misaligned, fucked it, and carried on
Old 02-16-2021, 06:35 PM   #626
PoorMans180SX
It's my fault guys, although it wasn't your typical install. Video will be up in a couple hours with all the mistakes I made on this thing haha. Luckily it is salvageable, but I'm going to be refreshing my spare subframe with a few new twists to replace this thing for now.
Old 02-16-2021, 07:35 PM   #627
PoorMans180SX
It's here:
http://www.youtube.com/watch?v=m2D5wJpgpOs
Old 02-16-2021, 08:11 PM   #628
RalliartRsX
Trader Rating: (32)
Now I feel bad for calling you a jackass as I actually respect your builds lol
P.S the surface rust on the rear rotor matches your beard color hahahaha!
Old 02-16-2021, 08:28 PM   #629
PoorMans180SX
Hhahahaahahah, it's all good man, it was a bad idea, just something I rushed to get done and I've paid the price for it! Trashing these bushings and going a totally new approach on this next subframe, so hopefully I can redeem myself.
Hahaha indeed it does, especially under that 6k LED!
Old 02-21-2021, 01:00 PM   #630
PoorMans180SX
It?s okay guys, I never want to watch other people?s vlogs either 🤣.
http://www.youtube.com/watch?v=-pZMUcg4LgQ
