I'm if it's possible to put a sr or rb into an auto 240sx, because I was thinking about ecu programming fuel curves and so on oh and transmissions and just could somone educate me on the 240sx's i'm new incase you dident realize. Thanks to anyone that helps me out.
![]() Join Date: Feb 2002
If your lucky....you can obtain a front clip with an auto tranny. It's very rare, but I've seen it done before (SR20 and RB25).
Goals are dreams with a deadline. L.H.O.O.Q. |
i've actuly done it left hand drive but it's quite unsafe for other drivers, lol reaching to my right lol what do you mean by front clip.. the front part of the chassie with like.. dash forwards?
![]() Join Date: Nov 2004
A clip is a car that is cut from the a pillar forward. So when you purchace a clip it has everything you need most of the time. Things like tranny, motor, dash, radiator, sometimes bodyparts. You can also be lucky and get mods.
But I wouldn't suggest that. Because chances are that it'll be a beat down motor. So it's up to you.
i'm scared for this guy. you better keep Power steering on that car
I didn't buy an Audi because it is a Great Car, but for more of a reason to be an asshole. |
actuly i have a 93 cavalier z24 w/o power stearing lol just hard to turn when your parking or driving slow lol but keep these suggestions coming guys i'm learning and getting good ideas. for my future project
#15 | |
Inactive Admin
![]() Join Date: Mar 2002
#16 | |
AFC #1
![]() Join Date: Oct 2003
Just about every importer I've seen has had at least one auto SR instock. I assume it's for when someone blow's theirs. Just have to talk with an importer and get a front clip.
#17 | ||
http://neotechimports.com/top.html
go there. call john, they have a new container to fill up in Japan, ask him to get you an automatic SR or RB, might have a long wait time, of course when you call, see if they dont have it in stock, or know of anyone that does...if all else fails, order it. |
#19 |
![]() Join Date: Dec 2002
The SR automatic transmission is the same unit as the KA (and Z32 NA) so you can just swap the bellhousing if you don't find an auto clip. The only drawback is the auto units are only good for about 300whp, and they're prone to blow out solenoids on the way up to that mark.
Also like mentioned, an automatic clip is generally a lot cheaper and has seen less abuse, much better solution if you're looking for it to last. |
#20 |
idk if this is ok but ... here's a site that does this exact swap ...
hope this help ... it is relatively more expensive but hence you need it so im putting up the link http://www.builtperformance.com/Main...Mlaborate.html they do everything .... but because you are located in michigan... and the shop is around ny... idk ... also bad thing is ... they dont' have a phone number which sucks... but email em for more details if needed... |
#21 |
my boss has i believe 2 RB25 auto trannys currently at the shop. i will ask him if he wants to sell it when i see him. although it might be cheaper to find a clip with a AT already. if it comes down to it and you need an auto RB tranny, hit me up and i can see what i can do.
