Does anyone know where this ground wire goes to? [Solved]
I noticed this wire has been hanging and my 89 240sx is in limp mode and i unplug sensors and the car sounds better
and now when i switch my ignition on the off position the car is still running even with the key out and with the battery unplugged the only way i get it to shut off is if I take out the efi relay. I have no clue on what's going on. https://imgur.com/a/HTI6AfjUpdate: i replaced the chassis and engine harness from a manual and ecu now the car runs and revs pass 2,500 rpms now Last edited by Eviltaco805; 08-06-2018 at 04:10 PM.. |
![]() Join Date: Jun 2003
Trader Rating: (129)
whoa dude that's way too many things.
what sensors did you unplug? what is "limp mode"? was the car running fine before? did you change anything or modify anything? or was the car running fine one day, you changed nothing, and then the problem started? we need a lot more information than you're providing. my best guess is you damaged something in the ignition switch, and now its not triggering the EGI relay to go open. |
#3 | |
#4 | |
Step 1: verify that your maf wiring is good. This might be as simple as a shitty or corroded connection. You can get electrical terminal cleaner at autozone, and a wire brush or toothbrush. |
okay so i recently looked at my chassis harness and noticed a lot of stuff has been bypassed and hacked up so im just going to replace the harness and noticed my dash harness also has been hacked up too so ill have to replace those and hope that fixes the problem. also i had a question about will a dual cam chassis harness and dash harness work on my 89 s13?
Or you can just check your maf wiring and get it running now and change the harness later. Don’t make it more difficult than it is. The tell tale symptom is that you can’t rev past 2500rpm - it’s the maf or wiring to it
![]() 5.3 V8 Swap w/ Nitrous |
#9 | |
