Old 01-26-2018, 11:01 AM   #1
slyblaznbboi
slyblaznbboi is an unknown quantity at this point
ID Check: Output Flange
All,
I'm having trouble finding the correct c-clip for my output shaft and it continues to pop out of my 2-way diff. The previous owner clearly modded this flange, but any help in the right direction would be greatly appreciated.
https://tinyurl.com/ycnd5sw6
slyblaznbboi is offline   Reply With Quote
Old 01-26-2018, 03:34 PM   #2
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
Originally Posted by slyblaznbboi View Post
All,
Chances are it was cut because he had problems with it himself
My question is, how is it sliding out far enough for it to not catch? Are you running the right length axles ?
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 02-01-2018, 09:40 AM   #3
Atill93
Atill93 is making his/her stupidity well-knownAtill93 is making his/her stupidity well-knownAtill93 is making his/her stupidity well-knownAtill93 is making his/her stupidity well-known
is the output shaft supposed to have a c-clip inside the pumpkin?
Atill93 is offline   Reply With Quote
Old 02-01-2018, 09:51 AM   #4
TheRealSy90
TheRealSy90's Avatar
All,
It looks to me like you're trying to use a VLSD output shaft. Almost every 2-way on the market for our cars uses the open differential output shafts. Obviously the previous owner tried to make it fit but they aren't correct.
All stub shafts have a circlip at the inboard end of the splines to hold the stub shaft into the differential.
Such a good signature.
Old 02-01-2018, 04:17 PM   #5
Atill93
wow thanks, I didn't realize that. the previous owner of my coupe must have not put the clips back in when he modified my diff. my output shafts slide right out after I unbolt the axle lol and that maybe explains the leak coming out of my diff
