![]() Join Date: Feb 2004
You mean this?
http://www.courtesyparts.com/40056x-...-p-137472.html Just in case you didn't know, the link is for a S14, IF you have a S13 you will need to order the bolts for a S13 since they are smaller. |
#4 | |
GM2 (SW/AW)
I mean you can, not entirely sure how you snapped them in the first place. I have some if you need them though.
i was replacing the whole front suspension and the wouldn't budge torched em and they still ended up snapping. if they're for an s13 ill take em how much do you want for them? i need the bot the bolts and nuts
Backorder are you sure? Shows that it will ship in 2days from warehouse.
Bolt http://www.courtesyparts.com/54302e-...419_1508_1510& Nut http://www.courtesyparts.com/56110b-...4-p-70247.html |
Ha, didn't add them to cart, check to see is anyone is parting out their car on here. I would even check local wrecking yards, you should be able to find some that will work.
#9 | ||
GM2 (SW/AW)
Apparently someone missed the part where I said I had them readily available.
