Power Enterprise B-A-N-A-N-A-S
We have a shipment thats arriving. Here is what we have available.
Power enterprise head gaskets. -87mm 1.1 thickness - $177 -87mm 1.5 thickness - $177 -88mm 1.1 thickness - $177 -88mm 1.5 thickness - $177 ![]() ![]() -PE1420SP Turbo Kit (PS13・RPS13) - retail is $1660, your cost $1245 ![]() -550cc Injectors - $492 -660cc Injectors - $812 -850cc Injectors - $462 ![]() -S13/S14 Radiator + hose set - $685.30 If you have any questions feel free to pm me. thanks guys |
Oh snap!!! Power Enterprise is legit!!
Power Enterprise head gaskets are on the same level as HKS/Tomei/Apexi ~ good stuff!
#9 | |
Compressor wheel ID 45.5mm, OD 60.0mm # of blades 6+6 Turbine Wheel OD 48mm Ex wheel Diameter 44.0mm # of blades 8 Turbine wheel design : slanted-flow Center shaft : ball Bearings Waste gate ID 23.0mm PE1420 (Rated [email protected]/cm2-5700 rpm, [email protected]/cm2-6300 rpm) |
#10 | |
![]() Join Date: Feb 2004
#11 | |
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
Quoted for troof. Serious business, Cometic price.
