Old 06-27-2005, 07:52 AM   #1
twelvea
twelvea is an unknown quantity at this point
Trying to take out injectors.
Ok im trying to take out my injectors(I searched and nothing), HOW THE HELL IS THIS DONE, killme I cant get them out, I broke some of the plastic off so I stoped, Im trying to take them out to put some 370s in, also if I put in 370's with out anything else will in not run right??
twelvea is offline   Reply With Quote
Old 06-27-2005, 07:58 AM   #2
skatanic28
skatanic28's Avatar
skatanic28 is an unknown quantity at this point
Send a message via AIM to skatanic28
you need some sort of fuel control to use those injectors. (safc, ecu tune, e-manage)
for the injectors.....i ended up threading the cap screws in about halfway and using the indents in the side of the injector top to pry them out. nothing broke that way and it only took like 5 minutes.
skatanic28 is offline   Reply With Quote
Old 06-27-2005, 08:25 AM   #3
twelvea
hmm wa u mean take them out with the caps on??? how?
Old 06-27-2005, 08:50 AM   #4
96twofourty
96twofourty is an unknown quantity at this point
you take off the caps (metal pieces held on with two screws) then you twist and pull the injectors straight up
Buy my stuff:
#/f/announcement.php?f=10
96twofourty is offline   Reply With Quote
Old 06-28-2005, 12:13 AM   #5
skatanic28
skatanic28's Avatar
i took the caps off, then threaded the screws back in about half way. then you can get some leverage with a small screwdriver and lift em out.
