240sx 15x9 +0 Fitment
For anyone who is curious about a 15x9 +0 offset on springs and coilover or clearence.
Rim/Wheels: Rota grid v (White, all 15x9+0) I'll try to make this short. My car with Se wheel, sitting on stock shock, and lower tein springs. Attachment 71199 Attachment 71200 Attachment 71201 Looks pretty good with stock wheels but after installing the grid v, the look change, I thought it was funnying looking. Tein spings: Attachment 71205 How the car and Fitment looks. Attachment 71202 Attachment 71203 Attachment 71204 This look is with no camber, but tire size is 195/60/r15 on a 15x9+0. I know, what a fat chunk of meat on the wheel. After that, I installed the coilover kit I bought, not the best but it works. Godspeed coilover, mono tubes, They ride good, I never ride in any other brand so I can't give you much about it, but it's smooth and it works. Attachment 71206 After I install these, the ride look a bit better, and it's still without camber, just natural butterfly. Attachment 71207 Attachment 71208 Attachment 71209 Attachment 71210 Attachment 71211 Attachment 71212 Overall, I didn't problem with them other then getting smaller lug nut because the stock didn't fit. brake all clears, but I have to roll the fender, I did it with rubber hammer and a heat gun that I can use different heat temp. I did have to pull up the harness by the driver side fender because it was burning. I just tie it with the engine pop up hood cable. with this high, my pipe would strach on driverway, and I can't go through small speed bumpers but I can clear the big speed bumps, sometime. But the wheels fits but it's better if you get coilover on it, size 15 looks better low then kinda low. I set my coilover rear stiff and front kinda stiff so I don't rub my fenders. There it is, anyone that wanna see a lot of photo of how it sits. Sorry if this didn't help you slove your problem. but it's worth a try. |
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
none of your pics work champ... and we already have a thread for small sized wheels and their fitment
#/f/showthread.php?t=406086 THREAD LOCKED! |
| +0 offset, 15x9, fitment, rota grid v, wheel |
