![]() Join Date: Sep 2013
Looking to trade my car for something else. I'm more than willing to add cash for a trade up. No bikes please, already have one. Would trade up for a nice G35 Sedan/G37 Sedan CAR IS SOLD I'm in central Florida. Please contact via PM Details: 1993 SE Coupe - Pearl White with black roof (Not super bad, could use a repaint) SE Model - Power Everything Auto Transmission (Have a full 5 speed swap waiting to go in) Engine: KA24DE 120xxx New plugs & wires New dizzy rotor New air filter EGR covered with Isis plate, AIV removed & Swirl still connected for secondary butterflies Charcoal canister deleted, tank vented Metal flake valve cover ISIS Megaphone MB SE exhaust system Chassis: 30mm 300zx aluminum front calipers, Project Silvia lines with new slotted and drilled rotors New OEM Z32 1" BMC 5 Lug Swapped New Konig Deceptions 18x9 +15 on new Nankang NS-20 235/40 (less then 500 miles) (2 spare 18x8 +20 of same wheels with new fuzion tires) Newer crackless power sunroof installed Powered By Max Coilovers (less then 500 miles) Powered By Max Rear camber arms (less then 500 miles) Isis tension rods Energy bushings for steering rack New door strikers Repainted some exterior parts (black plastic headlight buckets, front chuki bumper vents, wiper arms & rear window trims, b-pillar covers. Items also clear coated for protection) Interior: Whites LEDs in cluster & most interior lights (Haven't done map lights yet) S14 Seats | Recently conditioned Radio Trim Suede wrapped Pioneer AVH-X3600BHS touch screen head unit (Bought new) Deleted Stock Nissan Amps Kenwood KFC-G16206.5" speakers (Nothing special) (6.5" adapters for front speakers) Cluster has been replaced (Tach stopped working in the old cluster) Parts I currently have waiting for install: Previously rebuilt 5 speed transmission New Circuit Sports V3 short shifter New White Bunny clutch kit New Driveshaft shop steel driveshaft New DIF stainless clutch line 6 New flywheel bolts New Manual transmission swap bolt kit (Bell housing/Trans Mount/Slave) Trans Mount New slave & master Shifter dust boot 5 Speed dustplate New rear main seal Clutch pedal installed with master New rear window molding (Brakes pedal cut down & covered with brake pedal cover) Cons: Could use a repaint (Not terribly bad paint on it now, just a few blemishes) Driver side front fender is dimpled AC needs a charge Does have a small oil drip Body does have some small nicks in it (It's 21 years old, what did you suspect) Video: New Pictures from this morning 1/13/15: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by FLG; 05-13-2015 at 07:48 PM.. |
| 240sx, coupe, florida, s13 |
