Old 01-01-2010, 09:57 PM   #91
KoukiMonsta
KoukiMonsta's Avatar
can anyone give me info, a video something about AN fittings (oil filter relocation) i cant get these things together!!
@UpshiftEngineering
Old 01-02-2010, 12:35 AM   #92
boostdd
boostdd is an unknown quantity at this point
I have z front calipers on my s14, what kind of offset do I need to clear them? Meaning what's the lowest I can go ? Thanks
boostdd is offline   Reply With Quote
Old 01-02-2010, 12:38 AM   #93
95KA-Turbo
95KA-Turbo's Avatar
The offset doesn't matter as much as the type of wheel face you get. When people say their wheels have 'low disk', 'o-disk', or 'super-low disk' or something long those lines that means there is not much room for brake calipers. That usually means the wheel has more concave or a larger lip then maybe expected.
Instagram - SJKnoop
Old 01-02-2010, 01:33 AM   #94
slow40sx
slow40sx's Avatar
do they make stock body fiberglass front fenders for s13's?
Old 01-02-2010, 01:33 AM   #95
rbsilvias13
rbsilvias13's Avatar
rbsilvias13 is an unknown quantity at this point
Ok..i searched this and came up with nothing. So on S13 sil headlights i.e. dual projectors, there is two adjustment screws. one is to lower or raise the light beam and the other is for.....? thanks.
rbsilvias13 is offline   Reply With Quote
Old 01-02-2010, 01:34 AM   #96
slow40sx
slow40sx's Avatar
adjust it across the X axis? 1 for up and down 1 for side to side
Old 01-02-2010, 01:36 AM   #97
rbsilvias13
Ya i tried that cuz i thought thats what it was for and nothing happend lol. soo idk :] thanks.
Old 01-02-2010, 01:38 AM   #98
slow40sx
slow40sx's Avatar
haha thats gotta be what its for, it could be it just didn't adjust it enough for u to notice
Old 01-02-2010, 01:42 AM   #99
rbsilvias13
i guess lol. ill try some more. thanks again.
Old 01-02-2010, 05:08 AM   #100
lflkajfj12123
no sir they do not
extreme dimensions was working on a ventless overfender but its shit
Old 01-02-2010, 10:12 AM   #101
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Send a message via AIM to hOngsterr
one goes up down, other should be side to side, (on a graph Y & X)
correct.
they move little by little, try covering one side and adjusting one side at a time, make sure you have a flat wall to do it on lol.
you sir are correct again.
doooo it.
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
hOngsterr is offline   Reply With Quote
Old 01-02-2010, 12:37 PM   #102
kalypso123
(ノಠ益ಠ)ノ彡
The 'Other' forum has a DIY oil cooler how-to...
Old 01-02-2010, 12:38 PM   #103
kalypso123
(ノಠ益ಠ)ノ彡
Question..
Why or How can spacers where out you're hubs.
Old 01-02-2010, 01:09 PM   #104
derek_s13
derek_s13's Avatar
derek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant future
Send a message via AIM to derek_s13
Originally Posted by kalypso123 View Post
Question..
wikipedia leverage, specifically the word 'fulcrum' and the result if it's placement on a plane
derek_s13 is offline   Reply With Quote
Old 01-02-2010, 01:14 PM   #105
vin diesel
vin diesel's Avatar
vin diesel is an unknown quantity at this point
i cant remember what that s13 hatch that looks like a mr2 hatch is called. its the flat one. with the small rear window.
vin diesel is offline   Reply With Quote
Old 01-02-2010, 01:19 PM   #106
Nizmo_max
Nizmo_max's Avatar
Nizmo_max is an unknown quantity at this point
Okay..i got one..for all you guys that are running 17x9.5 +15 mb battles with 225/235 45/40 in tires..whats the lowest size spacer NEEDED to clear coilovers in the fronts on a s14..thanks??
Nizmo_max is offline   Reply With Quote
Old 01-02-2010, 01:22 PM   #107
bboyoracle
bboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to behold
Send a message via AIM to bboyoracle
Its made by yamato bit sports.
œYAMATO Official web‚ւ悤‚±‚»Iœ
bboyoracle is offline   Reply With Quote
Old 01-02-2010, 02:17 PM   #108
rbsilvias13
Question..
Most wheels are made to run in the center of the hub so it doesnt put alot of stress on the bearing and when you change that with spacers or an offset wheel it puts more load/leverage on the bearings.
Old 01-02-2010, 02:18 PM   #109
95KA-Turbo
95KA-Turbo's Avatar
It depends on the coilovers.
That sized/offset should clear most coilovers without a problem. Since a 225/235 is stretched you will not have to worry about the tire hitting.
Instagram - SJKnoop
Old 01-02-2010, 02:55 PM   #110
S14_Kouki
S14_Kouki's Avatar
Yeah I guess it depends on what coilovers. I have the same set-up in the front with stance gr+ and I dont have any probs.
S14_Kouki is offline   Reply With Quote
Old 01-02-2010, 03:02 PM   #111
XnTroubleX
XnTroubleX's Avatar
XnTroubleX is an unknown quantity at this point
Alright guys, I bought my S13 about two months ago and the previous owner installed a HUGE annoying tach on the dash above the center vents, I would like to remove it and just use the stock gauges, but the car has a SR swap and the stock tach and speedo doesnt work,, i wandering if the gauges not working is caused by the swap?? and if so what can I do to have a speedo and a working tach without having to put another huge annoying one on the dash!
XnTroubleX is offline   Reply With Quote
Old 01-02-2010, 03:20 PM   #112
95KA-Turbo
95KA-Turbo's Avatar
Is the car a 89-90? If so you need to get a 91-94 cluster...maybe a few other things. I've never owned a S13 but I know the clusters are different between the SOHC and DOHC motors. It should be a relatively easy fix.
Instagram - SJKnoop
Old 01-02-2010, 03:29 PM   #113
XnTroubleX
XnTroubleX's Avatar
The car itself is a 90' but I was told that the motor is prob a 94 model due to the cooling fins.
Old 01-02-2010, 03:35 PM   #114
95KA-Turbo
95KA-Turbo's Avatar
It doen't matter what year the motor is. If you swap a DOHC KA or SR20 into a 89-90 240sx you have to swap out the cluster and do some very simple wiring on your F plug.
Instagram - SJKnoop
Old 01-02-2010, 03:39 PM   #115
XnTroubleX
XnTroubleX's Avatar
So as far as what to buy, i just need to get a S13 DOHC gauge cluster?
Old 01-02-2010, 04:08 PM   #116
Nizmo_max
Nizmo_max's Avatar
okay in that case im rollin on megan streets...
Old 01-02-2010, 04:17 PM   #117
boostdd
Oh i see, hope i don't come across this issue
Old 01-02-2010, 07:05 PM   #118
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
BN SPORTS
some were on sale on zilvia couple months ago,
its "rare"
Originally Posted by bboyoracle View Post
have no idea if its the same company,
but yeah.(not saying your wrong)
- Hong
Old 01-02-2010, 07:19 PM   #119
slow40sx
slow40sx's Avatar
i mean throw em on and try it out, if it rubs get some 3mm spacers, thats what i did
Old 01-02-2010, 07:20 PM   #120
slow40sx
slow40sx's Avatar
no sir they do not
what are the smallest fronts they make do u know?
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki
