![]() Join Date: Feb 2010
z32 pins and clips same as r32 calipers?
like topic says I am wondering if the clips and pins from Z32 calipers will fit/work for r32 calipers?
Unless you get some aftermarket ones that aren't to nissan specs, yes... the only potential fail is the pins are too short to get the wire spring into the ends
The actual retainer that gets clipped in on top is going to work even if it's off a mm or two |
