vh45 w/z32 swap
I've search and I just can't find the right answer.. so sorry if it's been asked..
I'm doing a vh45 swap in my 240sx and I'm running a TT 300zx trans. This is what I've got and I was wondering if it will all work or not TT transmission NA flywheel NA clutch NA starter I'm planning on using the xcessive Kit for the set up. Any help would be great.. I'm hoping it all works Thanks |
![]() Join Date: Nov 2007
Contact Eric at performancevh.com for mounts for mounts and adapter plate. He's got everything you should need for a vh/z32 swap.
GIGGITY GIGGITY GIGGITY GOOOO!!!!
Sorry... didn't realize this was for a 240 at first... he has a good adapter plate for the tranny at least. He uses 1/4" steel plate so you don't need a spacer for the flywheel.
