Hazard light not working. Help!
Hey I'm trying to get my hazard lights working for safety reasons on my daily 92 s13. The turn signals work fine but the hazard lights doesn't work whenever I try to turn it on. I tried replacing the hazard light/turn signal flasher (O'Reilly brand) but the same thing happened. Maybe just a bad flasher? I opened up the timing control unit (white box under the fuse box on driver kick panel) doesn't look burnt. Don't have another one to check if that's bad so I just opened and inspected it. I checked all fuses, looks good. Idk what else to check/look for. Anything else I'm missing? Any answer that will lead in the right direction is much appreciated.
Sent from my Z970 using Tapatalk |
![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 16 reviews
I'm have problems with my turn signals....idk about my hazard as I have the gutted right now
What's the part number on the flasher relay...I want to try a new one |
I believe ep34 is the flasher part number.
If your hazard button is unplugged your turn signals won't work. I don't have any turn signals right now but hazards work fine. |
