![]() Join Date: Sep 2011
350z offsets.
anyone got a good idea on the best offset for the 350z? im thinking the following
18x9.5 +12 in the front and tires 225/40ZR18 19x10.5 +15 in the rear and tires 245/40ZR18 anyone got a better set up? |
simple answer: they will fit
complicated answer: go to a 350z forum and see.. there are quite a few running negative and even double digit negative offsets... so asking what is good will depend on the look you are going for... |
