Old 08-24-2017, 06:28 PM   #1
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
How to do a concentric twist wire harness? (Milspec/Racespec)
I have been looking into building my own wire harness, but have come up with limited "how to" on building a true milspec harness. I'm sure I'm not the only one, so I hope starting this thread could lead to helpful info for everyone. And books/videos/websites would be greatly beneficial to all. Also, if a similar thread exists, I apologize since I couldn't find it. Thank you everyone.
This is the most helpful piece of information I have found so far, but it doesn't quite tell you exactly what you do/don't need and exactly how to actually exicute certain parts of the harness. Also, interested in what tools are actually needed.
https://www.rbracing-rsr.com/wiring_ecu.html
Hoping people on here have even more helpful info!
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 08-24-2017, 09:15 PM   #2
BoredEE
BoredEE is an unknown quantity at this point
Look up J-STD-001 I can't recall if wiring harnesses are covered in that spec but it should cover general soldering techniques at the minimum.
Just a warning D38999 connectors can get quite expensive.
BoredEE is offline   Reply With Quote
Old 08-24-2017, 10:25 PM   #3
Imarvin240
Trader Rating: (18)
Ill look into that, thanks man. I have read so far that when doing a milspec/Racespec harness, no solder should be used because it creates a weak point. Crimping is the preferred connection in this type of harness.
