![]() Join Date: Jul 2012
Does anybody have any advice as to what i should look in to, as my car is running lean (idle) on cold starts as well as misfiring. Yet it is idling rich (12-12.4) once its been driven and warmed up. And still misfires a little. Vacuum during the cold start is at -20, but as it starts missing goes as low as -16. And then back to -20.
I set the engine at TDC and performed a boost/vacuum leak test using my air compressor and only found a leak in one of my intercooler couplers, which i fixed My o2 sensor voltage stays pegged at either high voltage (.86) or low voltage (0) when this happens too. Cruising around my afrs are fine and my o2 oscillates as it should. I am running lean under wot though. at 10psi and wot im getting roughly 12.7 a/f. Car has an enthalpy tune and has been having idle issues from the beginning, but at first my afrs under boost were fine. Was getting about 11.6 on my gauge. Martin is coming to the area next week and said he would find and fix the problem, even if it isnt tune related(which i dont think it is.) But i would much rather fix it myself and just him fine tune it. |
Guess i could have added that i did have my injectors tested and at 2ms (which is about equal to idle) pulse width there was a 20% difference between the four.
-2ms 112cc /min 100cc / min 92cc / min 93cc / min -8ms 686cc 676cc 656cc 667cc -Static 951cc 950cc 941cc 942cc Not sure if that info is useful or not |
MRP Manufacturing |
Would a bad cts cause lean cold start issues? And im not throwing any codes, but I guess it isn't unheard of to not throw codes and still have a component issue.
Im also not having hot start issues. Starts up every time. |
CTS doesn't seem to like to throw a code and has varying degrees of failure that cause poor running conditions.
MRP Manufacturing |
CTS is only about 1.5 years old.
And the car only started doing this stuff after adding the t2871r, z32 maf, sard 850cc injectors and the tune. Ive read that the maf being too close to the turbo can cause issues. Im running a kts (apexi replica?) suction pipe, but im not sure if it is too short. |
Yes, kind of lol. Martin at rs enthalpy said something was wrong with how the ecu was interpreting o2 feedback, or something like that. He worked his magic though and got it sorted out. Ill have to see what the car does tomorrow on a cold start though.
