Old 09-18-2002, 02:56 PM   #1
hopeful
hopeful is an unknown quantity at this point
Today while walking home from school I started thinkin... im never gonna get a car till I get to uni and when im there and i have a car i will be too busy with uni to bother with a car. So I just want to do somethign to help me waste time... I want to know the basics of welding like how to weld... i've seen it done and even done it once but i didnt set up the stick in the holding thing and just didnt ask enough questions. I heard of the different types of welders or welding methods? TIG, MIG, Wig? What are they? and what i plan on doing is just makin a go kart... but if its legal (i doubt it) what i was thinkin before was taking a car engine and mounting it up the frame... something small like 1600cc's RWD... man that thing would fly. I live in ontario if anyone knows about the laws.
hopeful is offline   Reply With Quote
Old 09-18-2002, 03:08 PM   #2
ca18guy
ca18guy's Avatar
ca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfection
IMHO TIG welding is better, here is a site explaining the two.
TIG or MIG weld
To learn it, either take a class or rent/buy a TIG welder plus helmet/gloves, some sheets of metal and pipe and have a crack at it.
ca18guy is offline   Reply With Quote
Old 09-18-2002, 03:38 PM   #3
hopeful
thanks man that was useful... so physically they both the same thing like same way of welding but TIG welding just gives you better results? at the end it says its harder... how is that? and what kind would i need to build a frmae of say aluminum?
Old 09-18-2002, 03:45 PM   #4
ca18guy
ca18guy's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (hopeful @ Sep. 19 2002,10:38)</td></tr><tr><td id="QUOTE">thanks man that was useful... so physically they both the same thing like same way of welding but TIG welding just gives you better results? at the end it says its harder... how is that? and what kind would i need to build a frmae of say aluminum?</td></tr></table><span id='postcolor'>
TIG can melt the actual metals together which is harder to do then MIG which lays down a sodder that you just melt alil and sets into place which if you ever worked on electronics is fairly easy. Atleast thats my take on it
Old 09-18-2002, 03:51 PM   #5
hopeful
does anyone have info on arc welding? the prices for the TIG welders are like more than halfmy budget for this thing i want to make.
Old 09-18-2002, 03:55 PM   #6
hopeful
so with tig i could get actaul metlas to fuse together but with mig it just lays down a coating of (what is it) and that holds it together.... i can see why tig's much better. but how much weight does the connection made by the stuff mig lays down take?
Old 09-18-2002, 03:55 PM   #7
ca18guy
ca18guy's Avatar
MIG/TIG is arc welding. &nbsp;Any hardware renting place ussually have them.
Old 09-18-2002, 04:09 PM   #8
hopeful
so its Tig or Mig depending on the type of rod i have? sorry for the sillyass questions but weldings like a whole big thing i didnt know it was so complicated.
Old 09-18-2002, 04:09 PM   #9
Pancor
Pancor is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (ca18guy @ Sep. 18 2002,4:45)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (hopeful @ Sep. 19 2002,10:38)</td></tr><tr><td id="QUOTE">thanks man that was useful... so physically they both the same thing like same way of welding but TIG welding just gives you better results? at the end it says its harder... how is that? and what kind would i need to build a frmae of say aluminum?</td></tr></table><span id='postcolor'>
TIG can melt the actual metals together which is harder to do then MIG which lays down a sodder that you just melt alil and sets into place which if you ever worked on electronics is fairly easy. Atleast thats my take on it</td></tr></table><span id='postcolor'>
uhh.. MIG and TIG welding both fuse the metals together using the same methods. &nbsp;The only difference is how the filler metal is added, and usually the type of current. &nbsp;With a MIG welder, the electrode is a roll of thin wire that is constantly fed through the gun to the arc to provide filler metal. &nbsp;With TIG, the electrode is non-consumable, and filler metal is added by hand with a small rod. &nbsp;In both case,s inert gases flow through the gun and keep the weld area from oxidizing. &nbsp;
MIG welding is by far the easiest method of hand welding, fllowed by oxy-acetylene, stick welding, and tig welding. &nbsp;For welding medium gage steel, i'd use a MIG or a stick welder, and for aluminum, a TIG welder is your best bet. &nbsp; Using oxy-acxetylene for aluminum is an option, but it can be difficult on anything but a flat, horizontal surface. &nbsp;MIG welding also works, but the aluminum wire is expensive and I think you need a special gas.
Pancor is offline   Reply With Quote
Old 09-18-2002, 04:15 PM   #10
ca18guy
ca18guy's Avatar
<!--QuoteBegin--Pancor+Sep. 19 2002,11<img src="#/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Pancor @ Sep. 19 2002,11<img src="#/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>9)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (ca18guy @ Sep. 18 2002,4:45)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (hopeful @ Sep. 19 2002,10:38)</td></tr><tr><td id="QUOTE">thanks man that was useful... so physically they both the same thing like same way of welding but TIG welding just gives you better results? at the end it says its harder... how is that? and what kind would i need to build a frmae of say aluminum?</td></tr></table><span id='postcolor'>
uhh.. MIG and TIG welding both fuse the metals together using the same methods. The only difference is how the filler metal is added, and usually the type of current. With a MIG welder, the electrode is a roll of thin wire that is constantly fed through the gun to the arc to provide filler metal. With TIG, the electrode is non-consumable, and filler metal is added by hand with a small rod. In both case,s inert gases flow through the gun and keep the weld area from oxidizing.
MIG welding is by far the easiest method of hand welding, fllowed by oxy-acetylene, stick welding, and tig welding. For welding medium gage steel, i'd use a MIG or a stick welder, and for aluminum, a TIG welder is your best bet. Using oxy-acxetylene for aluminum is an option, but it can be difficult on anything but a flat, horizontal surface. MIG welding also works, but the aluminum wire is expensive and I think you need a special gas.</td></tr></table><span id='postcolor'>
With TIG welding the filler isn't mandatory. You probably have a ton more experience then me with it so I would take your word on it.
EDIT: correct me if i'm wrong, i'm just a beginner still learning all the differences.
Old 09-18-2002, 04:18 PM   #11
DuceDual0
DuceDual0 is an unknown quantity at this point
sounds like fun!
SR20Fastback....TreDual..... and myself = Better than Garage SPL!
DuceDual0 is offline   Reply With Quote
Old 09-18-2002, 04:18 PM   #12
DuceDual0
sounds like fun fosho!
Old 09-18-2002, 04:24 PM   #13
ca18guy
ca18guy's Avatar
Dual stop post whoring your doing it in every section and noone apreciates it.
Old 09-18-2002, 05:15 PM   #14
hopeful
a special gas? i thought it ran off of electricity? what if its an arc welder thats not clled mig or tig? whats that make it?
Like whats this thign
arc welder
Old 09-18-2002, 06:03 PM   #15
jvh22a
jvh22a is an unknown quantity at this point
for welding steel you will need to use a mix of aragon/co2. &nbsp;for aluminum use all aragon. &nbsp;this is for tig or mig. &nbsp;there are other mixes too but this is the usual.
&nbsp;sign up for a welding class at a college. then sign up for a fee waver. &nbsp;gas, welding rod, is free...
&nbsp; for mig you can use a flux core wire. you will not have to use gas with this set up.
&nbsp;if you are going to get a unit; try the miller econo tig weld machine.
jvh22a is offline   Reply With Quote
Old 09-18-2002, 06:15 PM   #16
jvh22a
here is a pic of my tig inverter. only welds steel,stainless.
here is what to do:
&nbsp; -make a puddle
&nbsp; -then move the torch(not much),
&nbsp; -with the filler material, start at the edge of the puddle and gently shove the rod to the middle of the puddle.
&nbsp; -you will not have to use alot. depending on what and how you are welding it.usually less the 1/4.
there is more but it is all practice! &nbsp;
&nbsp;here is a pic of my manifold. &nbsp;tig welded i ran extra beads of some of the joints. you don't need to do this, but helps ease my mind when i drive
Old 09-18-2002, 07:24 PM   #17
DMCS14
DMCS14 is an unknown quantity at this point
as far as laws, if your not tryin to make it street legal you can do whatever you want.
DMCS14 is offline   Reply With Quote
Old 09-18-2002, 07:34 PM   #18
hopeful
about the laws thing...so i can drive it anywhere in ontario but official roads with only a G1 license?
So that entire exhaust manifold is made of stainless steel? looks nice tho... u can do so many things knowing how to weld.
how many amps is your tig?
tig thing
At the bottom of that page it says not to go for the flux ones, why whats wrong with them?
Old 09-18-2002, 07:43 PM   #19
luke91
luke91 is an unknown quantity at this point
ARC welding: &nbsp;Also referred to as "stick welding". &nbsp;Probably the most common medium for large scale, commercial welding. &nbsp;Industrial applications. &nbsp;Good for welding thicker, solid peices of metal. &nbsp;NOT good for automotive applications
MIG welding. &nbsp;Also referred to as "wire feed welding". &nbsp;The most practical of the three. &nbsp;MIG welders are inexpensive, can weld a variety of metals because the gas and wire are readily available, and practical for smaller-scale work on thinner metal. &nbsp;GREAT for body work, fabricating motor mounts, exhausts, manifolds, intercooler piping, etc. &nbsp;MIG welding is also better suited for "over-head" work, because it allows for the use of flux-core wire. &nbsp;In over-head situatuations, the inert gasses (argon) used with regular wire fall down, never touching the weld. &nbsp;Flux core wire keeps inert gases on the weld at all times, but produces more "splatter". &nbsp;
TIG welding: &nbsp;Also referred to as "TIG welding". &nbsp;The slowest, most precise of the three. &nbsp;Like MIG welding, TIG welding is better suited for small scale work, with thinner metals. &nbsp;UNLIKE MIG welding, TIG welding gives you much cleaner results with less or no "splatter", better suited for airtight, or pressurized situations (like radiator or intercooler construction), and allows for better control of the situation. &nbsp;TIG welders are simple, but expensive. &nbsp; &nbsp;
All three of the above welding techniques involve adding metal to join metals. &nbsp;If you join metals without adding metal, just by melting the two together, you are brazing, not welding. &nbsp;Hope this helps. &nbsp;
--luke
'91 fastback. &nbsp;'97 S13 blktop SR20DET. &nbsp;Cstm Frnt Mnt IC w/ cstm 2 1/2&quot; piping. &nbsp;stnls stl fltr. &nbsp;3&quot; cstm DP &amp; exhst w/N1 muff. &nbsp;Walbro FP. &nbsp;ACT 6 pck cltch. &nbsp;Go Fast Bits crnk plly. &nbsp;Ground Control coils. &nbsp;KYB AGX shks. &nbsp;[email protected] w/g-tech pro. &nbsp;17psi. &nbsp;All work and fabrication done by ME
luke91 is offline   Reply With Quote
Old 09-18-2002, 07:53 PM   #20
hopeful
thanks man that was alot of help.. is brazing an all round better technique for say making a aluminum frame..... to me it sounds like a stronger bond
Old 09-18-2002, 11:39 PM   #21
luke91
noooooooo.
Brazing is just about useless, in my opinion. &nbsp;If you're welding aluminum, MIG or TIG it. &nbsp;
Do what I did. &nbsp;Go buy a MIG welder for aroun $300. &nbsp;Buy two &nbsp;tanks, one for argon mix, and one for argon. &nbsp;Then buy a roll of mild steel wire, stainless steel wire, and aluminum wire. &nbsp;And a roll of flux. &nbsp;
Now, get good at welding, and charge all your friends to weld custom exhausts, IC piping, and all kinds of little shit. &nbsp;It'll pay off. &nbsp;
Or pay someone to weld it for you. &nbsp;
--luke
Old 09-19-2002, 05:23 PM   #22
formeRiceR
formeRiceR is an unknown quantity at this point
so what kind of metals are good for intakes and stuff...I have access to a MIG welder, it has argon gas and and I don't remeber the wire type...I'm afraid that the metal will rust and get into the engine...
&quot;Street racers don't need girls.&quot; -Lonely Driver
Learning about cars one FLAME at a time ... (thanks to TNORD)
formeRiceR is offline   Reply With Quote
