E85
What's up everyone I'm considering goin e85 on my s13 with my 30r and wanted to know some info on what y'all are running. So if you can post your
injector size fuel pump turbo and psi and hp/tq numbers if you can so I can plan my setup. Thanks |
![]() Join Date: Sep 2002
Your gonna have to give this thread abt a yr or so, e85 is slowly catching on. I'm interested as well for my next ka-t build.
91 Bmw 318is 90 S13 (sr20det) Last edited by SxMachine; 08-09-2010 at 07:18 PM.. |
![]() Join Date: Dec 2004
Trader Rating: (58)
Hey Jason:
Check out member: 4x4le (#/f/members/4x4le.html) for more informaton on E85. He also uses Nistune, so I'm certain he would be able to provide you with some pointers ![]()
![]() Join Date: Apr 2004
I used it. Was definitely faster than 93 octane, and I don't think I ever pushed the limits of timing on it.
#9 | |
ID-1000's
Walbro Intank, Bosch inline Aeromotive FPR PT HP6262 Didn't touch timing. 585whp Brandon - 4x4le knows alot about e85, great resource and very helpful guy. Quote:
Who's running a 2871r around nashville thats putting down 430whp ? I did 360whp with my 2871r 56trim on a dyno dynamic dyno on a base tune at 19.5psi. |
e85
i was thinking about running e85 too.... but cali only have two pumps that are not really that close at all.... is it possible to run pump gas low boost and e85 on high boost? like two different maps?
![]() Join Date: Sep 2009
![]() Feedback Score: 15 reviews
u can get barrels shipped to ur house i believe. my buddy's friend use to do that.
straights are for fast cars, corners are for fast drivers. |
#13 | |
Protip: If you ask questions like this you're not ready for a setup that's beyond the usual "buy a chip/EMS that's tuned by someone else and run around on the street" level.
#17 |
![]() Join Date: Jun 2008
I did at first, nothing bad happened but from what i herd it eats away at the lines/ is corrosive, it didnt happen to me but im on steel braided lines now with an Aeromotive FPR and precision top feed 1000cc injectors with a GT2871r, its yet to get tuned but i have high expectations for it.
this is mine but its hard to see cell phone pic FTL of course because its going to be lean as fuck without a tune, you need to add alot more fuel than regular gasoline. im sure it ran awful. |
#19 |
my car is not done yet, but i have an e85 set up, ID2000 injectors, twin in-tank denso fuel pumps, and a pte DBB billet wheel 6262 turbo, expect 775+ in the vegas heat. i think i remember that you need 30% more fuel on e85. but im not possitive
and i think you can run stock lines, but im running all steel braded AN fitted lines, fuel and oil. |
#20 |
![]() Join Date: Aug 2005
S13 SR20det
FP 18g turbo at 23PSI 92lb injectors Aeromotive FPR S.S. lines and fuel filter 10 Micron Walbro fuel pump rewired AEM EMS 355whp/318wtq dynoed at Beyondredline in Green Bay, WI |
