Nissan harbody 5 speed?
I tried searching but could find the information i was looking for. Since the harbody pickups have the ka engine, could i use the 5 speed transmission out of one of those in my s13? I thought i read somewhere that I could, but can't seem to find it now. Thanks in advance.
So know one knows for sure if the ka truck 5 speed transmission will work in a 240sx? There are no other s13 or s14's in my area for parts, but the local wrecking yard has atleast half a dozen Nissan pickups.
Sent from my SCH-I545 using Tapatalk 2 |
![]() Join Date: Jul 2005
I've seen an sr20det swapped into a hardbody nissan. Used an automatic though.
Had to make motor mounts too, welded em in. Ran pretty good, but that old redtop T-25 just doesn't push the truck like it does a 240sx, especially in front of an automatic. I think it went 14's or 15's at the track with stock 7psi of boost. And I remember the hardest part of the swap was getting the transmission to shift properly. It had issues from day 1. Finally got it 90% sorted by using the transmission computer from a 1991 240sx. Anyways to the point- since when is transmission length an issue? make a mount, make a driveshaft, make a cut, or don't trouble it /thread |
