Hey,
Would like some input about the problem I'm having with starting my car. It's a 95' 240sx LE with a KA24DE. When I stick the key in and try to start the car, it sounds like it partially starts but just doesn't get there. It's not the battery; all my electronics work. I thought it was the distributor cap/rotor so I replaced that because it looked pretty worn out when I took it off. I also changed the spark plugs, now using NGK Iridiums. After replacing the distributor cap/rotor/spark plugs, it still wouldn't start immediately but after playing around with the gas pedal, it started. Since then, I've started the car a couple times without problem but the engine makes a faint clicking noise... "chik chik chik".... constantly. Any ideas as to what the problem could be? Any input would be greatly appreciated. Thanks in advance, Barry |
![]() Join Date: Mar 2003
battery could be dead. a weak battery is strong enough to turn on your electronics but not strong enough to turn over the engine.
engine could be flooded. liquids dont compress -> locked. starter could be dead. bang on it with a hammer. alternately, try push starting the car. |
![]() Join Date: Oct 2004
try starting your car while someone taps your starter with a hammer. by tap, i mean, "hit fairly damn hard" and the "chik chik chik" could be a tensioner or a chain guide or a valve. Try to figure out where its coming from
high performance driveway photography zenki s14---v8 fc rx7 my crappy flickr page (drift cars whoo) |
