Tein Coilovers for S13 Enjoy awesome pricing with shipping included for the lower 48 states. You won't find a better deal so act fast bruh! ![]() Basic Coilovers ![]() • Ride Height adjustable via spring seat • Twin Tube internal construction • 1-year Manufacturers Defect Warranty $930 SHIPPED Notes: Not EDFC Compatiable Ride Height Adj Range (R): -1.1~-2.9in Ride Height Adj Range (F): -1~-2.5in Spring Rate (R): 336lbs/in (6k) Spring Rate (F): 336lbs/in (6k) Uppermount: OEM Uppermount TEIN type BASIC damper offers a high quality coilover system at an entry level price. Drivers will feel in increase in stability, and grip, while maintaining good ride quality on the street and freeway. A shortened shell case is utilized to allow for better ride and improved performance at lowered ride heights. BASIC damper is a great option for consumers wanting a simple and quality made coilover. Each application is test fitted and road tested to ensure the best possible balance between comfort and performance on the street. Includes ride height adjustment to give your vehicle a minor to major drop. Additional Features: • Steel Construction • Twin Tube internal construction • Larger piston diameter for strut type front and rear (22mm) • Ride Height adjustable via spring seat • Powder coated damper body with Zinc coated threaded section • 1-year Manufacturers Defect Warranty • Available for Overhaul Flex Coilovers ![]() • EDFC (Electronic Damping Force Controller) compatible • Upper camber adjustment on front for strut type vehicles PM us for pricing, can't post BRAH! Too good. Ride Height Adj Range (F): -1.1~-3.1in Ride Height Adj Range (R): -1.4~-3in Spring Rate (F): 392lbs/in (7k) Spring Rate (R): 392lbs/in (7k) Uppermount: PillowballUppermount TEIN has used its years of experience in various motor sports to produce a kit that provides the ultimate balance between comfort and performance. Developed for drivers seeking an aggressive coilover that can be used daily, and provide all the adjustments needed for circuit use. The FLEX damper Kit features the latest technology for all drivers who are seeking performance, and adjustability, while not giving up all ride comfort. They have incorporated separate spring perch height, and shell case length adjustment, which allows the suspension to retain more stroke and allows for more suspension tuning. The FLEX damper kit includes pillow ball upper mounts, which increase steering response; 16 levels of damping force adjustment, and is compatible with the EDFC (Electronic Damping Force Controller) for added convenience and adjustability. Additional Features: • Steel Construction • Twin Tube internal construction • Ride Height adjustable via threaded body and spring seats • 16 way adjustable dampers, compression and rebound combined • Pillow ball upper mounts for increased steering feel • Upper camber adjustment on front for strut type vehicles • Larger piston diameter for strut type front and rear (22mm) • EDFC (Electronic Damping Force Controller) compatible • Powder coated brackets with Teflon coated shock body for heavy duty rust prevention • 1-year Manufacturers Defect Warranty Sorry for the lack of S14 love. We promise we'll have something good for you guys very soon ![]() Cool beans. Adios.
10kRedline.com Free shipping on any order over $500* Contact us: [email protected] Like us on Facebook |
Le Monday bump!!
replies sent etc
Tuesday BAMP
Bump!!!!!!!!
