Problems with Stance coils
So I have some stance gr+ coilovers & I’m trying to lower my car more. but I THINK i’ve already bottomed out the threads on the lower mount of the coilovers in the rear with at least 3” left of adjustability left, anyone else have this problem? if so what did you do?
If you’re here to troll, move along please. |
As long as you're adjusting from the bottom mount and it cannot turn no more, then you reached the lowest. The only other way to go "lower" is to buy shorter shocks from Stance.
For example, I am running front shocks as my rears on my set of PBM coilovers (replaced my V1 shocks). The only con is I cannot raise the car to stock form since im limited on the height of the shocks.
