![]() Join Date: Nov 2010
Z33/34 6 speed. Destroying Csc's! Anyone else?
So I have an sr20 with the maverick Motorsport adapter plate fitted to an 08 z trans and I've been thru two concentric slave cylinders with less than 3k miles.
I am running a new master cylinder and a spec stage 3 pp and clutch, is anyone else running into these issues wit an aftermarket pressure plate? I am gonna start saving for the zspeed hd csc or the csc elimination kit
![]() Join Date: Mar 2009
I'll be going with the zspeed csc myself, got talked into it from someone that has been beating on his for a long time with no issues. The elimination kit just seems like too much stuff to wear out or break to me. Until it's further tested
![]() Join Date: Jun 2011
I had the same problem until i went with z speed's csc. better off with that than the elimination kit imo. i've been dailying mine with a spec stage 3 clutch for about 5k miles.
