![]() Join Date: Feb 2012
Isis t28 install question?
okay so i just got my isis t28 in, along with the isis bottom mount turbo lines, the turbo came with a paper that says not to remove the oil feed banjo bolt and fitting from the turbo, but i think i should remove it to put the oil feed line in?
and yes I have looked it up, and can't find a clear answer on this, so I'm asking for opinions/experiences with this same problem. ![]() |
Disregard my retarded self, figured it out. (i think) I was just supposed to take the fitting off the isis turbo lines and use the fitting that came with the turbo.
![]() Last edited by Little Jason; 07-28-2013 at 09:35 PM.. |
![]() Join Date: Nov 2010
The reason for the banjo is it has the correct size restrictor for that turbo. You can use the other -an fitting you had pictured, if its the correct size restrictor
