![]() Join Date: Mar 2014
Hey everyone! Made a different thread for my part out, going a different route with my build i'm selling off all parts on this car that are SR20 related.
Parts location: Palmdale, CA 93551 Huge parts list, Please comment in what you're interested in below! Any specific SR20 parts that are on the motor that you're interested in that aren't listed PM me and I can give you a price for it. PM me for Shipping costs if you want anything below! Parts list as of December 20, 2016 Engine -Takata Race 4 ASM Green Harnesses - $280/Each ![]() ![]() -CP Pistons & Eagle Rods (Came out of my blown SR, I'm not sure if they're even good; Sold as is) $200obo ![]() ![]() ![]() ![]() ![]() -A'PEXi Power Intake for Z32 MAF(Almost new condition) - $55 ![]() -Nissan S13 SR20DET Coil Packs (4) - $50 ![]() -GSWerks Custom Baffled Oil Catch can - $40 ![]() -Circuit Sports Oil Cooler Adapter with Oil cooler lines, all you need is a new oil cooler core - $50 ![]() No photos as of Dec.20(Will upload some soon) -Nissan S13 SR20DET 5-Speed transmission, 2nd grinds $50 Picked up -VIS Carbon Fiber Trunk(Needs Work) - $100 Picked up -Greddy Oil Filter SR20- $6 Parts Sold as of December.20.2016 -Tanabe Revel ELS Gauge (Boost)(SOLD) -AEM Wideband Air/Fuel Ratio Gauge(SOLD) -Tanabe Revel ELS Gauge (Oil Pressure)(SOLD) -9K Racing 150mm Shift knob(SOLD) -Koyo Racing Radiator Cap(SOLD) -Koyorad Radiator w/Electric Fans & Shroud(SOLD) -Samco Silicon Radiator Hoses w/ Greddy Thermostat Sensor(SOLD) -Z32 MAF(SOLD) -S13 SR20DET Power Steering pump(SOLD) -Nismo Adjustable Fuel Pressure Regulator-Type B(SOLD) -S15 SpecR Dual Ball bearing T28 Turbo without other stuff(No shaft play)(SOLD) -555cc Tomei Fuel Injectors(SOLD) -Apexi Power FC L-jetro(MAF) for Nissan 240sx SR20DET w/FC Commander(REDTOP, Model #414-N014)(SOLD) -Greddy SR20DET Oil pan(SOLD) -B&M Short Shifter(SOLD) -S13 Radio Bezel(SOLD) -Circuit Sports Engine mounts(SOLD) -Parts by Max HMIC Complete Kit(T28 Turbo, OEM S13 SR or Greddy Intake manifold)(SOLD) -Nissan Z32 BM-57 Master Brake Cylinder(SOLD) -Parts by Max Super Angle Knuckle(SOLD) -Parts by Max Front Lower Control Arm + Tension Rod Combo (BENT)(SOLD) -Parts by Max Traction Rod(SOLD) -Gramlights 57DR 17x9 +22 Square(SOLD) -SPL Pro V5 Outer Tie Rod Ends(SOLD) -TEIN Hardened Inner Tie Rods(SOLD) -Parts by Max Pro Toe Rod(SOLD) -Parts by Max Rear Upper Control Arms(SOLD) -Uncracked S13 Dash(SOLD) -Siliva S13 Brick's Headlights(SOLD) -Parts by Max Flex Cobra Downpipe(For T28 Turbos) wrapped in Mishimoto heat wrap(SOLD) -Circuit Sports Brake Master Cylinder Heat Shield S13 with Mishimoto Thermal Tape(SOLD) -Parts by Max Turbo Inlet pipe for T28 style turbo for Z32 MAF(SOLD) -Mishimoto X-Line Aluminum Radiator(MMRAD-S13-89SRX), 1989-1994(SOLD) -Bride Seat Rails Pair(Passenger & Driver)(SOLD) -Parts by Max MaxPro Coil-Overs(less then 30 miles)(SOLD) -Parts by Max Rear Drop Knuckles(less then 30 miles)(SOLD) -S13 Chase Bays Fender well Brake Lines for Z32 Calipers(SOLD) -Hydro Dual Caliper Full Bolt On Set-up: (ASD 16’’ Pull back Universal Hydraulic E-Brake 3/4 , Custom Lines Included)(SOLD) -89-99 Kaaz 2-Way Diff 240sx (Great Condition, Low miles) with Final Drive & 5 Bolt output shafts(SOLD) -Nissan SR20DET T28 Compressor inlet(SOLD) -Nissan SR20DET T28 Compressor Outlet(SOLD) -Nissan Z32 Aluminum 30mm Front Caliper Pair(SOLD) -Nissan Z32 Aluminum Rear Caliper Pair(Comes with hardware and stock pads)(SOLD) -Parts By Max S13 Skid Plate (Gold)(SOLD) -Nissan SR20 Notchtop Valve cover Black(SOLD) -Nissan S13 Door covers(SOLD) -ATP Manual Boost controller(SOLD) -Nissan SR20DET T25 Compressor inlet(SOLD) -Mishimoto S13 Aluminum Fan Shroud (#MMFS-S13-89SR)(SOLD) -NRG Steering Hub lock(SOLD) -Frozen boost 31”x11.75”x3” Bar and Plate 600HP Capable intercooler with new Silicon couplers(SOLD) -Nissan Z32 Aluminum Rear Caliper Pair(Comes with hardware no pads(SOLD) -Porterfield R4 AP460 Front brake pads for z32(SOLD) -Porterfield R4 AP461 Rear brake pads for z32(SOLD) -Parts by Max RLCA(less then 30 miles)(SOLD) Enjoy! Last edited by R2RO; 12-20-2016 at 02:05 AM.. |
Bump, Parts sold recently
-Greddy SR20 Oil pan -Z32 MAF -Samco Radiator hoses. Pm me if your interested in any item on the list above or message me if you want a part from the motor. |
Bump, Parts sold yesterday
-S13 SR20DET Power Steering pump -Nismo Adjustable Fuel Pressure Regulator-Type B Pm me if you want any and all parts SR related, thanks guys |
-S15 SpecR Dual Ball bearing T28 Turbo without other stuff(No shaft play) -555cc Tomei Fuel Injectors Pm me if you want any and all parts SR related, thanks guys! |
Bump added photos of the B&M Shifter.
Also I cannot ship out the PBM Skid Plate & Cobra Flex Downpipe, since I don't have boxes big enough to fit them in. Sorry for the inconvenience! Those Items are reserved for Pick up in Southern California only at the moment. |
#20 |
Bump, all parts listed above are still available unless otherwise stated as sold.
Parts only available for pick up in Southern California: -PBM Skid Plate(Gold) $80 Picked up -PBM Cobra Flex Downpipe $260 Picked up Available in Northridge, CA or Palmdale, CA. |
#22 |
Decided to sell the PBM HMIC complete set
$330 shipped Less then 10 miles on it, perfect running order Its specifically spec'd for S13 SR20DET's With T28 Turbo and Stock intake manifold(I have an optional pipe for those running the Greddy/Freddy Intake manifolds). Comes with: -PBM HMIC Core -PBM Cold Pipe for OEM S13 SR20DET & KA intake Manifolds(Wrapped with Mishimoto Gold heat tape)(I have Greddy Style Cold pipe too) -PBM Hot Pipe for T28 Turbo(Wrapped with Mishimoto Gold heat tape) Awesome setup but I rather part with the whole system, since I wont be using the pipes for my new build. Picture of it is the first on the thread, More coming soon. |
#25 |
Decided to just part out the whole car, All parts up for grabs! PM Quick! Photos of the parts will be available later this week! Still have Finals till thursday.
#29 |
![]() Join Date: Dec 2008
Can you cut a package deal for the rear PBM suspension links and the inner and outer tie rods shipped to 87107 (business address)
What gen are the super angle knuckles? |
| california, drift car, drifting, s13, sr20det 240sx s13 |
