![]() Join Date: Mar 2007
OFFER! Toshiba Tablet, UR Pulley, NGK wires, Crank/Rods, Tools
Bumps would be greatly appreciated :-D
Everything is OBO. My name is Fred, text 503-550-9410 or PM. For trade I am looking for a wideband, misc suspension, Aluminum Driveshaft S13 non-abs, Apexi Rev Speed Meter, Apexi ELII White w/silver bezel water temp/oil temp/oil pressure gauge, Nismotronic for S13 KA24de, etc etc just let me know whatever you have, doesn't hurt to ask. Unorthodox crank pulley KA24DE in great shape SOLD THANK YOU! Freshly machined KA24DE crankshaft with good rods, will require .25 undersized bearings $150 Toshiba Excite 32GB 10.1" tablet android ICS with case and USB OTG/HDMI adapters. Barely used like new in box- SOLD I no longer need my NGK spark plug wires. They only have a couple thousand miles on them and are in great condition minus the coil wire. The coil wire just needs a new connector/boot on one end cause my msd connector was on there and I needed it for my new wires, maybe on the other too cause it turned yellow, I believe from resistance heating(bad connection to the distributor cap) but it was working fine when I took them off. If you have an S14 KA with an internal coil than you don't need it.They retail for about $75 or $65 for the s14 ones without the coil wire. I'm just asking $45 shipped. (not my pic)just an example of how they look installed Actual wire set -Fix busted threads such as your timing chain idler pulley bolt(ka24de) with this NAPA Heli-coil kit for M12x1.25 PLUS the necessary drill bit(31/64, good quality from Ace Hardware). All this only used once for $40+shipping. RIVETER SOLD! Last edited by Pirate_Freder; 07-24-2013 at 02:38 PM.. |
#9 | |
GM2 (SW/AW)
Food for thought, don't advertise that the wires you're trying to sell, were burnt... if its yellow its not worth buying. the rubber shielding may look fine but the core can be fried...
I certainly appreciate the input. Im just being honest and straight forward. As i said in my listing though its only the coil wire due to poor contact and someone with an s14 doesnt need that wire, all of the others wires are in great shape.
