![]() Join Date: Nov 2003
I need a stock front pipe and cat for my '91 and I can get one from a SOHC.... will it fit or not? I know this is sort of a newb question, but I had never really thought about it...
it should s13 and exhausts should be the same from dual to single cam, i ordered the SSA s13 exhaust on my sohc and it fits perfect, and i know of people with a DOHC running the same exhaust.
you should be fine! |
![]() Join Date: Dec 2002
You guys are tearing up that reading thing.
Manifold and downpipe do NOT swap over. Why? Different head. Any of the 91-98 parts will work though if you have both pieces.
#8 | |
AFC #1
![]() Join Date: Oct 2003
Just wait for the CA to put the SSA in. I don't know your timeline but, I would get a OBX header off ebay and run it till you get the CA set up then resell the header. |
SOHC exhaust mani's (and exhaust ports) are spaced like this: 0-0----0-0
DOHC exhaust mani's (and ports) are equidistant, thus: 0--0--0--0 Someone correct me if I'm wrong.
C4L #34 |
#10 | |
#11 | |
the E has a different head so different headers, you need a 91 headers and downward to the car , i know this i get a KA24e and a 24de in my garageright now . As far as exhaust being vehicle specific its not really the shape of bending of the exhast , thats usually the same if there is the same motor what really changes are the hangar locations
