![]() Join Date: Aug 2005
I was wondering what this part is called and where I can get another one...or the part number if from nissan. I cant seem to find it on the diagrams. It would help if I knew the exact name for it....so I come here.
This should be off an 89 nissan 240sx. What this part is... The wireing harness has the connection to the positive battery terminal and this slides onto the side of that. Thank you for any help. |
just put ring terminals on the end of the wires that go into that plug and put the terminal bolt through the hole in the ring terminals. works fine and gets rid of that massive ugly black connection plug
![]() Join Date: Dec 2008
That's basically all I did as well but I have one of those gold plated audio terminals and it is about 4 connections.
1990 Nissan 240SX w/KA24DE - New project 1984 Mazda RX-7 GSL-SE 13B |
| battery, connector |
