Vh45 swap issues
93 motor in 93 s13
All 8 injectors firing New KS's Harness by JSimpson Deleted egr and iavc All pcv lines vented Starts up fine every time, hits a nasty rev limiter around 4k rpms. Really fast like anti lag. Not maf limiter. Tried multiple ecu's also. |
![]() Join Date: Feb 2005
Timing? No shit, my project fired up every time to, and it was off a link....seems like the ECU is pulling timing when you rev it?
You could try pulling the TPS and see if it changes the behavior to rule that out...you check coilpack resistance? |
#3 | |
Sent from my SAMSUNG-SM-G890A using Tapatalk |
