Hello everyone!, I bought this s13 that was sitting for a while and the previous owner cut the positive and negative terminals of the batter for unknown reasons, as I was working on it I bought a wiring specialties harness to replace my transmission harness, it already comes with a positive terminal and it only needs the alternator/starter wires to be wired into it, my question is what are these 3 white wires that come out of the fuse box, I had people tell me they were 12v wires to the positive terminal, can anyone confirm?....
sorry to bother, new to this s13 thing. ![]() link to the photos: https://photos.app.goo.gl/dmZdkU8NniDAkcwS6 |
![]() Join Date: Nov 2016
If I?m not mistaken, you see your positive terminal that has a red plastic protruding with some male connectors in it, I believe those wires go there.
#4 | |
https://photos.app.goo.gl/3uu2L6BCPvNou1Xg6 |
![]() Join Date: Sep 2012
two wire plug is for left and right headlight power, single large wire is main fusebox/chassis power.
You'd be better off putting ring terminals on them or getting a set screw battery terminal.
@jz_2tone |
