Clutch issues
i have an issue that nobody can figure out with my clutch, that after driving the car for a few mintues the clutch pedals slowly rises and the clutch slips but when it cools it'll grab on but it'll start all over again.changed both cylinder replaced the clutch twice and flywheel and bled the line so many times oh replace the rear main seal.
Im havin the same problem, you may want to check the main rear seal (keeps oil from your engine from getting on your clutch), my issue is that it will drive fine when it first starts and cold, and then once it warms up if i give it too much throttle it will slip... this is what i was told to check... (my clutch is brand new and proffessionally installed) so anyways, im checkin mine tomorrow, i will keep you posted if u havent figured it out already... so i didnt read the last like 4 words u wrote... if u figure it out post the problem please...
my clutch was install professionally too and I told the mechcanic about this issue I was having he said he'll check it out but the main rear seal was fine, I've ask others they say it may be my flywheel was loose or some leakage of oil may combine with the tranny fulid and cause the clutch to slip.
